Question about Northgate (STAX2517C2) PC Desktop
Help i put 2 12" audiobahn with a rockfordfosqare punch p325.1 amp it was working find until now when i turn it up it go on and off then stay on for a wait then power cord start to melt then the fuse blow on my power cord that connected to battery
    Scholar:
  • 72 Answers
If your power cord starts to melt before the fuse blows it means you have *way* too thin power cables. Then the fuse probably blew because of a short to ground due to the melted insulation. This is one of the things that can start car fires.
I use cables of similar thickness as jumper cables to my slightly bigger amp, maybe a little overkill but better safe than sorry.
Posted on May 28, 2009
  • Håkan Sterner May 29, 2009
    Considering the lack of feedback or follow up information from you, OP, what more would you like to know? What additional information do you need in order to solve the problem you have?
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
My audiobahn amplifier isnt working, the status
it maybe fixable. the problem is that when you find what is burnt or messed up, you replace it. after that you need to find out why it burnt or messed up. i wouldnt recomend trying to fix it your self unless you wanna chance it. but if you take it to a technician that can fix it the will be able to tell you if it can be repaired. also check your power and ground wires. make sure youre getting 12 volts to the amp. check your subs and make sure they are good. a bad sub will put a amp into protect. good luck.
Dec 17, 2009 | AudioBahn A2300HCT Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
I need to know how to hook up 2 punch p3 fifteen
Depending on your impedance you want and the ohm rating of your subs, your wiring will vary.
Check out this calculator which will tell you the correct wiring to achieve whatever load you need for the amp to work comfortably.
http://www.lightningaudio.com/latech/wiringwizard.asp
Mar 22, 2009 | AudioBahn A1300HCQ Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Audiobahn A1500HCT in Protection Mode
try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
Northgate (STAX2517C2) PC Desktop Logo
46 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
