Question about OKI C3400N Single Pass Color Printer
Error Message/Black toner empty
I have an OKI Data 3400n my friend filled the cartridge and it is still reading Black Toner Empty. What more can I do? I am having the same problem. However I also was thinking like jolilakame when he was saying how the RFID chips work and how the PRINTER keeps the counts. However I bought 3 sets of chips and found that the RFID chips were the ones that actually kept the count and NOT THE PRINTER. When I took a used RFID chip that registered empty in one printer and put the chip on a totally new machine (for the first time) the new machine registed the chip as "toner emtpy". I also moved the chip to different toner slots and experienced the same result. I even tried to cycle through the 3 sets of chips, and that one RFID chip that registed empty still registers empty no matter where I put it, or what machine I put it in. I don't know if there's a way around preventing a "write" to the chips. However there must be a FACTORY RESET that will clear the original "starter" count. Does anybody know what the "TEST" button does on the back of the machine (near the USB and LAN ports?)
  • edavin May 29, 2009
    No I think the chip is most likely fine. The printer does recognize the chip because it does read "toner empty". If the chip was damaged it will say "Toner not installed" or "Non genuine toner detected..."
    Also the fact that the printer started with a "toner low message" before I got the "toner empty" probably indicates the the printer does WRITE to the chip.
    BTW: this message was in response to another posting on teh Okidata c3400n where someone suggested to get a few sets of chips because it was the printer that kept the count, and that the printer can only remember a limited amount of chips. Meaning that after a few sets, you may use an old set and since the printer "forgot" these chips, it will think it's a new set and reset the toner counts. I realize now this is not the case.
Hi.
I tear apart the printer and i found that the rfid unit is working at 13.56 mhz with a chip from oki mhm2045-00, i was unable to find the chips datasheet. i suggest you to buy a 13.56mhz rfid reader/writer and read an empty and a full chip to see the deferece they have and if you can clone a full chip and re-write the empty one. rfid reader/writer is very cheap at ebay.
please post any progress.
thank you.
Posted on Jul 02, 2009
  • 1 more comment
  • kmiers May 30, 2011
    This post is 2 years old I see, however still relevant.
    Most inkjet and laser printers keep the toner content count on the cart eeprom. The printer reads the cart toner level on startup and re-writes new level back to card every 10 prints, etc, as the toner/ink is used.
    Surely no-one has suggested the toner/ink content is stored 'on the printer', it usually isin't in my expereince. If the toner/ink level is shown on printer LCD it is being displayed from the current carts eeproms - since that is the current level, it having been written back.
    My printer is Xante Ilumina (aka Oki C9600 with Xante firmware). I am trying to read the toner chips. The chip is MH2046. I don't know the mhz. The chip does not activate a 13.56 mhz Mifare card reader. Maybe this version Oki machine does not have 13.56mhz RFID system. Maybe it is 125khz. The toner chip PCB has 10 coils in its aerial.
    I am searching for way to read edit re-write it.
  • ownaginatios Jul 21, 2011
    Did you ever get any further with this? I also have an OKI printer with MH2046 chips (OKI C3530n MFP).
  • kmiers Jul 21, 2011
    Hi, No progress. My Oki 9600 is running but not my Ilumina. I bought one 'new' black illumina chip and it still made running CMYK error on all colours. Then I bought full illumina CMYK 'new' chip set and fitted them. Still the same error. The aftermarket chip manufacturers can make and write their chips for these but for illumina apparently there are 'region' chips needed for the different world regions. So for NZ I need correct region. I also suspect incorrect toner may trigger the CMYK toner error, So if some incorrect toner has entered a drum then it needs to be vacuumed out, Oki 9300/9500 model toner can not be used in the c9600/9800 machines. iIlumina is a c9600 machine basically with different firmware and toner chips - different chip programme for each colour, whereas Oki c9600/9800 have same chip for each colour. I would like to read and write them, but the only way so far disclosed is to remove the outer top cover and invert the sensors, then start with good full or part full chips and after start change chip and print 10 prints, the printer will then write the new 'lower' toner level back to the chip. According to the post. the top must not be opened during the process, this is why the outer cover needs removal, to access the sensors and allow removal and inversion. Once chips are re-written the sensors can be replaced to original position and the cover replaced. this is only stated as valid for Oki c9600/9800 but should work on an illumina also.
  • 22 Answers
Your printer cartridge chip is damage you change Black toner cartridge
Posted on May 29, 2009
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
I need to clean out my Laser printer - OKI OL 400EX
I replenished the empty toner cartridge using the contents of a reduced price (from PCWorld) cx-OKI400l-is cartridge. For this you need a steady hand and a very small, very shiny stainless steel funnel. These are available from a good kitchenware shop. There is a removable cap to the cartridges. I understand one should only use the Toner from a cartridge by the same manufacturer as the printer. My old OKI OL400ex is now working again. I still don't have the answer to: Where does the excess Toner go? Does it fill up the printer drum? Michael UK
Jan 22, 2010 | Office Equipment & Supplies
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Most all new color laser printers employ an RFID reader adjacent to each of the 4 tomer cartridges. There is a unique RFID chip inside (under a small blue slide cover) each toner cartridge. Whan a new toner cartridge is installed, the printer "knows" such and begins a "countdown" of the number of prints that are made which utilize the toner in each of the 4 cartridges. Once a toner cartridge has "processed" the predetermined number of copies you will get a warning that the cartridge is almost empty and must be replaced. After an additional predetermined number of copies are processed, the integral computer within the printer will shut down the printer until the cartridge is "replaced". If you simply "refill" the same or original cartridge and re-install it into the printer, the same RFID chip is in the cartridge and the computer will not reset the print "counter", allowing you to start printing. You have to obtain another couple of new or "re-filled" cartridges (of the same color or black) from an outside source. The printers' internal computer does not keep a complete running list of all of the RFID chips that have been installed and used in the printer (maybe 2 or 3) and then then it is "1st in / 1st out" of the limited RFID memory of the printer. I have been unable to obtain a "Service Manual" for the OKI C3400n printer to determine how to do a "hard reset" of the internal computer. I know there is a way which would allow the "refilling" of the toner cartridges without having to buy an additional 2 of each color.
Dec 06, 2008 | OKI C3400N Single Pass Color Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Oki 3400n
First thing to do (if not yet done so) is to access the printer through the web admin interface by typing the printer's IP address in a browser. This gives a lot more information than the blinking lights.
The Status page of the web admin interface may say "toner low" or "toner empty" or "error on toner sensor" and that will tell us which color cartridge to handle.
Note that the OKI 3400n has the annoying tendency to fail when loading in a new toner cartridge: a color is low or empty, you put in a new color tube and then the printer says error on that very color! This can be fixed by pulling out the drum of that color (the drum is that entire block which includes the color tube and the container below it; avoid touching the shiny green roller), and lightly tapping on that drum to evenly distribute the new powder inside the container.
You may have noticed that the once the color tube is loaded in, what it does is to empty its content into the container below. Which means that it's no use swapping color tube once it's installed because the color tube is empty by then, and is just kept there to prevent the ink powder from spilling out of the container. The caontainer itself has 5 electrical contacts on its side used to measure the powder content and the lifetime of the drum.
Viet
Aug 29, 2008 | Office Equipment & Supplies
How to overcome the "Toner Empty" message?
hmmm..that toner empty issue is built into most printers, and it's not something that you can fake out, in most cases. Oki is telling you the straight stuff, here.
May 01, 2008 | OKI C3400N Single Pass Color Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
OKI C3400N Single Pass Color Printer Logo
2,933 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
