Paper jam When I load and try to print using inkjet or any other paper, it jams.....Standing in front of the machine, it is the left side that doesn't go through smoothly - crinkling and jamming....
  • 30 Answers
Hi,clean left side & clear any misfeed sheet in paper tray or left side.send me a result.
thank you.
Posted on May 29, 2009
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
scanner cover support down and close the scanner cover.
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Jammed paper
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
65 people viewed this question
k24674
