Question about Uniden Cordless Phone
No dial tone on other 2 handsets.
My base unit works the other 2 handsets do not.
Some one had the solution and it was so simple,all i had to do was to take the two handsets,and put them on the base for only a few seconds.thank you so very much. i was ready to take them back for a refund.again thank you.....
Posted on May 29, 2009
One handset on my uniden dxa13288-2 does not work. The battery is charged and good (swapped with other unit). When placed in masterbase, base led flashes, indicating good data marriage on both. The good...
The handset for this unit registers automatically to the base. The main base sync with the handset but it does not respond. The handset that is not responding has a problem and should to be replaced. You can pick one up on eBay for a few bucks.
Jun 02, 2017 | Uniden 2.4GHz Digital Answering System...
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Uniden Cordless Phone Logo
63 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
