Canon imageCLASS MF8170C All-In-One Laser Printer
Problem for Canon imageCLASS MF8170C All-In-One Laser Printer
E002 message won't go away, printer won't work!
By iblconsultan on May 28, 2009
I have a Canon Imageclass 8180c multifunction color laser printer. I keep getting a System error E-002 message. I have tried all solutions recommended by Canon support website, no luck.
Solution #1
posted on May 28, 2009
Not Rated)
vkyhunk
Rank: Guru
Rating: 91%, 617 votes
Hey Hi!i!ii!i!i!i,
Firstly Insert The Printer's Driver Software Disk In The Computer And Completely Uninstall The Printer Driver Software. Don't Remove It From Control Panel. You MayUse Any Uninstaller Software For Removing the Printer's Driver SoftwareAnd If You Don't Have The Printer's Driver Software Disk.Here's The LinkFor Uninstaller Software. ( It Will Work Only With WINDOWS OPERATINGSYSTEM)
http://wugnet.com/shareware/spow.asp?ID=638
Then Clear The Temp And Prefetch Files.
Disconnect the printer's cable form the back of the computer and disconnect printer's power cable and turn it off.
Press and hold the printer's power button for 30 Seconds then release it.
Turn off your computer and then disconnect all the cables from the back of the computer.
Press and hold the computer's power button for 30 Seconds then release it.
Wait 2 minutes.
Hook up monitor, mouse, keyboard, internet connection and power cable and then restart your computer.
Hook up printer's power cable and then turn it on.
Hook up printer to the computer.
Copy and paste the link below in your internet browser and then download and install the LATEST PRINTER'S DRIVER SOFTWARE AND FIRMWARE AVAILABLE, IF ANY..
WINDOWS XP
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=10561
WINDOWS VISTA
FOR ANY OTHER OPERATING SYSTEM KINDLY CHOOSE THE OPERATING SYSTEM.
Restart Your System.
Issue Resolved.
Feel Free If u need any further help.....Kindly Rate Solution..
Was this helpful?
Yes
No
Popular Solutions for Canon imageCLASS MF8170C
Questions and Unsolved Problems for Canon imageCLASS MF8170C
Do you recommend Canon imageCLASS MF8170C All-In-One Laser Printer?
Answer
Answer
The print is light and there is a 1 inch fade that runs across the page vertically. All toners are... (More)
Answer
something came through by fax and it is stuck in memory. It says change paper size cassette A4. ... (More)
Answer
I need to know how to use the bypass feature. Pictures would help. I want to use photo paper. Is... (More)
Answer
I am able to send fax but not receive. When a fax is coming in the phone does a slight ring and then... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageCLASS MF8170C...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
