Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W19 no power at all.
When I press the power button theres no green light or anything.
  • volcomschonk May 28, 2009
    Already have a topic open so ignore this post.
  • volcomschonk May 29, 2009
    Fuse is ok. Where is the main regulator located?
3 Suggested Answers
SOURCE: RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Posted on Apr 18, 2009
  • 53 Answers
SOURCE: i have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Posted on Aug 27, 2009
I have hdtv rca d52w19 green power lights shows
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Tv will not come on immediately...
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Dec 26, 2008 | RCA D52W19 52" Rear Projection Television
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
