Question about Lightolier Ivory Galaxy Slide Dimmer Switch 600w X600-i
End of Run Dimmer Switch Installation
Old switch has two posts - brass & silver. New dimmer has ground post, and two un-marked posts. Which one is the positive and which is the negative?
  • thebeverleys May 28, 2009
    Thanks! Much appreciated.
    Genius:
  • 1,605 Answers
Take a look at the old switch that you have taken out, just connected the new one as the old. with the ground to the switch box.
Since the new one is not marked, you can connect the black on either side of the switch.
Posted on May 28, 2009
Old dimmer switch has 2 black wires, one is attached to another black wire & the other is attached to a white wire. The new dimmer switch, Pass & Seymour legrand R600-PIV has 3 wires, 2 black...
If the directions didn't give you specific connections, look at the color of the stranded wire inside the insulation. If one is gold and one silver, the gold goes to the black incoming, the silver to the white incoming, and the green is ALWAYS ground.
If both of your stranded wires from the dimmer switch are silver, either can be connected to the black and white. Green is always ground.
I hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie andie
Apr 15, 2011 | Garden
Replacing old switch, existing leviton dimmer has two black wires coming out of it....can't firgure out which is which? Power, load, grounnd
Hook one of the wires that was connected to the black wire to the silver screw, one to the brass screw. Does not matter which. If there is no ground (bare or green) then you can hook one from the green screw on the switch to the box where the other grounds are connected.
Feb 13, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
Two wall sconces: pulled out old dimmer: 2 sets of romex and no ground. white wires wired together; two black wires, one hot. Installed new dimmer: on-off OK but only one light dims with buzzing. Dimmer is...
Okay. This is going to be easy.
You're in the middle of a circuit and that's why you have 2 Romex'.
The HOT black is the line side. It comes from the panel. The not-hot black is the load side. These 2 blacks go to the brass screws on the switch. The whites tie together and don't go to the switch, UNLESS there are 2 silver screws on it, then they go there. Watch the switch to see if it's clearly marked for LINE and LOAD. In that, the HOT black goes to LINE and it's white companion (from the same Romex) goes to the LINE silver screw. The 2 from the second Romex go to the screws marked LOAD.
In the sconces, you're going to find one that has 2 sets of wires and the other has one set. (I'm betting) The one that's working better, is the first one from the switch wiring.
Open the working one with the switch turned off, of course. Disconnect the wiring going to the second light. Make sure the first light works just like you want it to.
Now, take the 2nd sconce down and see if the wires are in the right places. White to white, black to black, grounds in place, protecting wires from the others. If all that looks fine, reconnect the wire running from the first light to the second. Even though these are still opened up. turn on the switch and see if the 2nd sconce works.
If it's still buzzing, try to determine exactly where the noise is coming from.
Some dimmers won't work with florescent bulbs, some don't like halogen bulbs. SOME don't like the energy-efficient curly bulbs!
The box/instructions for the new dimmer may point out what it's NOT compatible with.
If everything's connected correctly and there's still buzzing, I'm guessing that there's some mis-match between the new dimmer and the lights.
Feb 02, 2011 | Leviton Decora Light Dimmer Switch
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
I think I have a Leviton double pole dimmer switch. It used to operate track lighting along with an on/off light switch in the same room (different entrance). I replaced the track lighting with a fan...
You mention a dimmer and a 2nd on-off switch.
You purchased a 'double pole' switch which I believe is a 3-way switch.
3-way switch has 3 screws (plus ground screw which will not be mentioned further)
3 screws on 3-way switch = one is dark colored, and 2 are brass colored.
You can guess. There are only 3 wires and you can keep trying different combination until both switches work. Do not change wiring on 2nd switch and sooner or later the right combination will appear.
On the other hand, electricians test wires using ordinary tester, before connecting anything.
If you want to test, it takes 3 ez steps.
Here's what I would do.
1) Look at wiring on 2nd switch.
Notice switch has 1 dark screw and 2 brass screws.
If you can identify the two wires on the brass colored screws, these are the 'travelers' and same two wires connect to brass colored screws on new switch. And then last wire connects to dark colored screw.
2) You have noted the wires carefully on dimmer, so remove dimmer, and separate wires for testing.
2nd switch is moved to down position.
We are NOT going to test wires on 2nd switch.
We are just testing wires at old dimmer.
Turn on power.
Power is on.
2nd switch is in down position.
Test each wire to bare ground wire.
One and only one wire will light up the tester.
Mark this wire.
3) Change 2nd switch, and move 2nd switch to up position.
Test each wire again to bare ground wire.
Again only one wire will light up tester.
Mark this wire.
If same wire lights up tester each time, then this is the Hot wire and it connects to new switch dark screw. And the other two wires go to brass colored screws.
If a different wire lights up each time, then these two wires are 'travellers' and they connect to each brass colored screw. And the last wire connects to dark colored screw.
Dec 16, 2010 | Electrical Supplies
Master bathroom: GFCI combination outlet/switch to a dimmer to 3 recessed lights. I am not an electrician but I've wired most of the house myself with advice and Internet diagrams. This GFCI combo to a...
Dave, So you have a GFCI outlet, and a 3way switch and a 3way dimmer switch, right? First off, if you want the GFCI to protect the switches & light you will use both output terminals of the GFCI which have tape over them. The white wire (from the silver screw output of the GFCI) will go to the lights, passing through the switch boxes, but not connecting to anything. The black wire (from the brass screw output of the GFCI) will feed the first switch. Both the switch and the dimmer must have 3 terminals (plus ground). One terminal is the input/output, the other two are "travelers". On a full size switch the input/output will be on the top and the two travelers will be on the bottom (or upside down from this - the key is that the travelers will be on two sides of the switch but on one end. There will be 3 wires (plus ground) going between the two switch boxes 1-the neutral which does not connect to either switch, 2,3 the two travelers. Connect the two traveler wires to the two traveler terminals on the dimmer. The other terminal on the dimmer is the hot wire output to the lights. I hope you found this helpful. Good luck
Aug 17, 2010 | Home
I am replacing a 3 way light switch with a dimmer switch. The existing switch has the green ground, two black on one side and a red on the other. The new dimmer has the green ground, two red and one black....
There is no universal convention on the color coding of wires for three-way switches, other than green always being ground. Fortunately if you wire it wrong you won't hurt anything, it just won't work right. Two wires are "travelers", they run between one three-way switch and the other. The "travelers" were attached to opposite sides of one end of your old switch. From your description, one is red and one is black. (These two wires are interchangeable, except that in one position both toggles up or both down would ON. In the other position one toggle up and the other down would be ON.) The "third wire" was attached to the other end of the old switch and is black. If you can't tell by just looking at it which lead of the new switch is alone at one end of the new switch (and is therefore mate for the "third wire"), you can just try the combinations. Assuming you still know which black wire is your "third wire" there will only be 3 combos.
Jul 27, 2010 | Cooper Wiring Devices Three Way Grounded...
The store doesn't know what they are talking about. And I can't believe they told you to just keep switching wires. Hitting the wrong wires is an easy way to short the dimmer switch out. Take it back and go to Home Depot or Lowes and buy the same type switch you took out.
Mar 11, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
Need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Mar 09, 2009 | Electrical Supplies
Lightolier Ivory  Galaxy Slide Dimmer Switch 600w X600-i Logo
194 people viewed this question
Top Lightolier Electrical Supplies Experts
ken skalski
Steve
Tom Chichester
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
