Question about Acer Computers & Internet
Black ground with green/pink dash pattern. Pointer appears, nothing else works
My newer Acer monitor model X223W bd woke up today with a black screen laced with a green and pink dash pattern over a non-responsive black ground. I have dual monitors (one older) and can scroll my pointer onto the Acer monitor but nothing else appears. Anything I try to drag onto the Acer fails to appear, but the mouse pointer is still visible. Help!
  • 198 Answers
SOURCE: 1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SOURCE: Monitor
Input Not Supported: The Acer manual says to turn on the display BEFORE the computer. That must be done for plug-and-play to recognize the wide screen monitor.
Posted on Aug 21, 2008
budmrtn
  • 11361 Answers
SOURCE: Acer, AL2016W
Open up the set and look for bad caps, see example of a couple years old monitors that failed.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 08, 2010
  • 732 Answers
SOURCE: Dell 173FP - black screen - green flashing power LED
nofun846, Software won't help you. All the fixya lcd monitor tech's already know what the problem is. Monitor 's "switch-mode-power-supply"/"ccfl inverter supply" not working properly or has failed and gone into partial or full shutdown mode to try and save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. Do some reading in my fixya profile for about an hour and find out your options you have. Read the older stuff!! You already did one test. Do flashlight test also. Will you attempt DIY fix or contract out repair or just trade for new??? READ, READ, READ. and if you don't like my stuff, try "buddymc" and "budmrtn" two other very good fixya tech's here on fixya along with hunderds of other tech's. Also visit links to other web sites for more info on BLACK screen fixes. Good luck with repair. 12fixlouie
Posted on Mar 10, 2010
jmgldsmth
  • 1869 Answers
SOURCE: Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Posted on Jul 22, 2010
Have a Acer x223w monitor and it fades to white and then fade to black. I looked at the caps and nothing look blown on both boards. When I turn on the monitor the acer pops up and no signal look fine. But...
Have you verified that the problem is indeed your monitor and not the video card on your PC? i would start by connecting the monitor to a laptop or another PC to verify that the same issue occurs no matter what the source. Once you've verified that, you're likely dealing with a monitor that requires repair or replacement. Hopefully it's under warranty. Hope this helps a bit.
Aug 13, 2011 | Acer 22" X223w LCD Monitor
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
Suddenly my acer X223W lcd monitor goes blank and the light stays blue. I can barely see the images like in a 10% transparency filter. When I turn the lcd on everything is ok until the logon screen appears...
There is an "inverter" component inside the LCD monitor,
that creates all the "brightness" of the image.
That part is failing, and is becoming intermittent.
It's about a $20 part to replace, plus $50 for a qualified TV/computer technician to open the monitor, replace the part, and reassemble the monitor.
Jul 17, 2010 | Acer 22" X223w LCD Monitor
I have a black line at the top of my screen
THIS DEAD PIXEL.SO THIS IS NOT REPAIRABLE.IT WORK NORMALLY.DON,T FEARING.
Jul 06, 2010 | Acer 22" X223w LCD Monitor
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
A pink line the whole height of the monitor has
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Jul 18, 2009 | Acer 22" X223w LCD Monitor
Good Luck!
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
