Question about AEG T58840 Dryer Electric
The dryer doesn't tumble. Everything else seems to work fine except this! In the beginning I thought that it could be some kind of a belt problem but when I opened the top of the dryer I was not able to locate the problem.
  • dtmcmp May 29, 2009
    Clarification request from smart10U: When I opened the machine I could not see any belt.
    Clarification request to rupe45: AEG 57520 electronic lavatherm
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    with the machine open, can you see the belt around the drum?
  • 56 Answers
Need to know what brand of dryer youhave.
Posted on May 29, 2009
  • rupe45 May 29, 2009
    I dont have enough expeirence with AEG products I apologize for the inconvience
Hi, I have an AEG T35850 tumble dryer. The motor makes a buzzing sound as it slowly gets going when empty. If it has a really hard time getting started, most of the time failing to get going.
The most likely cause is a slipping drive belt from the motor to the drum. Check the tension on the belt, but if the belt is worn, replace it. If the belt has been slipping for a period of time , it will probably be worn out.
Motor making a buzzing sound, is the motor actually turning? If so it is probably the belt.
If motor not turning, try taking the drive belt off and if the motor now runs, you may have seized drum bearings = expensive, buy a new dryer !
May 03, 2016 | AEG t35850 7kg vented tumble electric...
Wt881 gorenje tumble dryer
Hello, I have a problem with the dryer, it doesn't dry to clothes off and everything else works fine. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else maybe?
May 26, 2011 | Dryers
The dryer works, heats, tumbles, everything is fine. Except that there is a thump as the drum turns that seems to be coming from the top.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jun 17, 2010 | Kenmore 93042 Gas Dryer
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Dryer was working fine before I left on vacation, came home and dryer has power, but it won't tumble. Timer seems to work for a few minutes then everything shuts down
HELLO im18; It may be sensers around the heating element that may have triped because there is a belt BROKEN that drives tumbler, and the air fan as well. You may have to get someone that knows about these things too fix it as well,sorry. John.....!
Aug 20, 2009 | Kenmore Dryers
The dryer will not tumble
do you hear any humming noise? does the heat come on?....no noise. most likely is a thermal fuse....small white fuse usually with two blue wires. humming means broken belt, bad motor or something stuck in blower wheel.
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
AEG T58840 Dryer Electric Logo
415 people viewed this question
Top AEG Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you an AEG Dryer Expert? Answer questions, earn points and help others
