Question about Garden
I want to replace the sprocket drum
How to replace sprocket drum in chainsaw
  • dontbother10
    dontbother10 May 11, 2010
    Inboard or outboard clutch? They are almost always left handed threads (tighten it to loosen it) This question cannot be properly answered as asked.
  • dontbother10
    We need the make model and serial numbers from the manufacturer's tag.
  • 157 Answers
Pull the bar cover and bar take a center punch and hammer and knock it loose the threads are counter clockwise
Posted on Sep 18, 2009
Tip
Ok, great advice. My sprocket is worn out and I ordered a replacement. It came,...
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
on Jan 06, 2010 | Garden
After installing the chain on the new poulan chainsaw, the sprocket gear will not turn, I made sure the cover nuts were loose upon tightening the chain but the sprocket gear will not turn with chain on,...
Did you make sure the brake was off before re fitting the side cover, if not the band will be smaller that the drum and will jam the drum and stop it from turning.
Aug 12, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Partner 370 how to replace worn sprocket drive on clutch drum
You need to remove the clutch there is a special tool that fits into the two cut a ways in the sides of the clutch centre, the tool then has a 19mm nut on the other end this allows you to jar the clutch off against the compression of the saw, the clutch is just spun onto the crank with a left hand thread so it needs to be jarred off clockwise, an impact gun with a 19mm socket will work very well, the tool is part no. 530031112, should be available on the web.
Jan 18, 2013 | Garden
I need to change the drive sprocket on a 028 av super i am having problem getting the old sprocket off whats the trick
is the chain brake still applied, thus gripping the drum on the sprocket.. Remove the E-clip and take the chain brake off... clutch drum should lift out.
Sep 15, 2012 | Stihl Garden
Sprocket will not turn on Stihl MS 180 chainsaw.
either the brake has come on, pull the hand guard firmly back to the top handle until the brake clicks off and try again, or the drum bearing has collapsed seizing the drum onto the crank.
Jun 22, 2012 | Stihl Garden
On my petrol chainsaw the cog that turns the chain is not moveing
The sprocket should be fixed to the outer clutch drum. With the engine off, and the bar and chain off, hold the sprocket with channel lock pliers and turn the outer clutch drum by hand. If the sprocket does not turn, but the drum does, then the clutch must be replaced. (Left hand threads) To keep the engine from turning while trying to remove the clutch internals, stuff starter cord into the upper cylinder head area so that the piston cannot rise above the top of the exhaust port. If you have a saw service shop near you, you might farm out the clutch replacement. It usually requires a special tool to turn the clutch internals. Good luck!
Jul 23, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Poulan Super25DA old chainsaw from the mid 70's.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Oct 01, 2009 | Garden
Need sprocket and drum parts for XL homelite chainsaw ut10656
any place that sell chain saws will have one,take the old one with you to be safe
Aug 28, 2009 | Homelite Garden
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
