Question about Tatung V30DMTT 29.6 in. LCD Television
PIn Hole on LCD TV
I have sony LCD TV, I just noticed it has a pin hole in the screen.
What can be done to fix this problem. If used what is the life expectince.
3 Suggested Answers
  • 17 Answers
SOURCE: small white hole on LCD screen
Sorry to be the bearer of bad news, but you have what is called a "dead" pixel. Only repair would be to replace the LCD. I would like to think you would not spend $1400 to fix this problem.
Posted on Jul 11, 2009
  • 60 Answers
SOURCE: I have a small hole in my dell lcd monitor that is always white.
not a thing you can do = your lucky the screen is still working , leave it be~ replace with new screen when you can
for safty you can always place a small pice of clear tape over it, wont improve txt but it will stop dirt getting in and might give you longer life with screen.
Posted on Aug 08, 2009
My hp lcd monitor screen is accidently suffered a pin hole. how to plug this pin hole to make screen normal and prevent white light from escaping from screen and read words on that part of screen which get...
LCD is Short for liquid crystal display, a type of display used in digital watches and many portable computers. LCD displays utilize two sheets of polarizing material with a liquid crystal solution between them. An electric current passed through the liquid causes the crystals to align so that light cannot pass through them. Each crystal, therefore, is like a shutter, either allowing light to pass through or blocking the light.
If you have a "hole" in it then you will most likely have to replace the display.
Aug 29, 2013 | HP Computers & Internet
Dell latitude c610 broken hinge
go www.dell.com give your service tag, model and download your instr. manula and service manual , parts and fix it.
God bless you
Sep 27, 2012 | Computers & Internet
I have a rear tine craftsman tiller and it keeps breaking the shear pins on the right outer tine. I have replace the pins several times. Same results. What could be causing the problem?
The hole is worn out so the pin has room to move around inside the hole which causes excess wear on the pin...this causes the pin to break after a period of use...
The best fix would be to have the hole welded up and then redrilled to the proper size again..
heatman101
Jun 25, 2011 | Garden
Brand new won't charge won't sync
If it was really bought brand new, there are only a few things that could be wrong with it.
The first and most likely thing is that it might have been used previously by someone or you were sold a fake of the controller.
On the other hand, it might have stayed quite a long time in the shop from which you purchased it and as a result the battery life-span has been exceeded.
Don't get down, there is one little thing you could do that might help.
You would need to look under the controller and look towards the top part and you would see a little, tiny pin-hole(you might not notice without looking close).
Get a pin and insert into this hole(this is the reset button for the ps3 controller, as it could help fix any problems with the controller).
If this doesn't work, make sure your usb charger is properly connected and functioning well, but if all these prove abortive, the best thing to do is to return it to the shop from where it was bought.
hope this helped you? please rate
Dec 26, 2010 | Sony Dual Shock 3 Controller for...
When i press the eject button ,it appears LOCKED in the dvd screen, plz help me to unlock it
takes; a flashlight and a sewing neddle or hat pin
to fix: using the flashlight, locate the pin hole located somwhere just below the disk tray. insert the neddle into the hole, and give a firm push . be sure to keep the neddle straight, as failure to do so will usually cause you to miss the carrage arm, hence the tray will not be released. when done correctly, you will feel the mechanisem release and traval inward, and the tray will pop open about an inch or so.
Nov 22, 2009 | JVC Televison & Video
Small white hole on LCD screen
Jul 11, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
I have a infocus that produces pin hole lights on screen
Yes it sounds like the LCD controller has died or dying if still under gaurentee take it back if not it wont be worth repairing.
Marc Engineer
Jun 16, 2009 | InFocus ScreenPlay 5700 Multimedia...
Buy and replace new watch band ?
I just replaced the band on a women's ironman watch, so I know it is tricky, but can be done. First remove the old band using a small flat blade screwdriver and determine that the spring bars that came with the new band are the right size by comparing with the old ones. My new ones were too large. Then, use a pen to make marks on the back of the watch case in alignment with the spring pin holes . Put a spring pin into the band and position the band on the watch the way it will be attached, with the pin just above the marks. Use the small flat blade screwdriver to insert one of the spring bars into its hole and align the other side of the spring bar with its mark on the case. Compress the spring bar and slide it down until it roughly aligns with its hole, then, push the band sideways toward the hole and wiggle the band until the pin seats. Apparently the hole alignment is very tight and, without that last step, the pin simply will not seat. After spending a lot of time with the first strap, locating the spring pin hole by trial and error, I used a magnifying light for the second strap to allow me to see the spring bar hole, making the process a lot faster.
Mar 13, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Emachines w3609
It was better if you have specified the brand of the cd drive. However the following would fix your problem.
1. If you have noticed earlier , check for a small hole ( the size of a pin ) on the front of the cd drive just below the tray which opens. depending upon the brand of the cd the whole might be located anywhere ( below or above, right or left corner ).
2. Having located the hole. Get yourself a Pin or a Safety Pin or a copper wire. Insert the pin or the wire inside the hole which will release the clamp inside and now manually try to pull the Cd drive with your finger nails..
You are done.
Hope to get rated as fixed.
Regards
Bzoy...
Dec 31, 2007 | Computers & Internet
Tatung V30DMTT 29.6 in. LCD Television Logo
765 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
