Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not drain (nd help code)
Had a repair person check for plugged hose or pump. He concluded it was a bad board. I bought a new board and it didn't solve the problem. He gave me part of a service manual that shows how to put the washer into "Board Output Test" by pushing the "rinse" key and it looks like if I do this and push the "presoaks" key, it will activate the pump and let me know if it is working (I will do it when the washer is full of water). It says you must be in service mode to to perform the board output test and the part of the manual that tells how to put the washer in service mode is missing. How do I put the washer in service mode? Am I on the right track or should I be looking at something else?
  • Anonymous May 28, 2009
    Thanks localwonder,
    I agree that I could see if the pump motor circuit is open, but it is also possible that it has an internal obstruction or a broken impeller so I thought if I could just get it into service mode and activate the pump when there is water in the washer, I could quicky see if the pump is working or not. If the pump, eficiently pumps down the tank, I will know to look elsewhere before I tear into it.
  • Michael Masters
    Michael Masters May 11, 2010
    Its much easier to just test the pump with a ohm meter.
I found that one the plastic features on the bottom of the pump housing that mount the pump to the sheet metal floor of the washer had broken off. This allowed the pump to move around during opperation which cause the power connections to become loose and have intermitant contact. I cleaned up the connections and used shills to tighten up the pump mount and it works fine. Pretty dissapointing to pay a "qualified" technician to come and overlook such a simple problem and tell me to buy a new board :(
Posted on Jun 01, 2009
Nd error code, what does this mean
ND stands for No Drain.
It means that either your drain is plugged, the piping inside your washer to the drain pump is plugged, your pump is damaged, your control panel is damaged or a combination of the above.
If you can hear your drain pump operating, you should check for blocked piping. If you have water in the washer, unhook your washer hose from the back of the washer and lower down to the floor to see if water drains from your washer. If little water runs out there is a good chance that the hoses inside your washer are plugged with something. If water runs out freely, then there is a problem with your pump that will not allow it to pump water up to your drain hookup.
Oct 04, 2014 | Samsung WF220AN Washer
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Samsung wf 210 front load washer nd code
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
May 21, 2014 | Hotpoint Aquarius WF210 Front Load Washer
New pump installed, still not working and nd code
look at ( have a technician look if you want to save money) at the program board for a problem there
Apr 25, 2017 | Samsung WF328AA Front Load Washer
Maytag 2400aaww Front loader had ND code. Want to see if the pump is clogged before I make a repair call or buy a new one. Had this problem before and paid through the nose to fix it. How do I access the...
ND means no drain, the water level fails to drop below the low water level in final spin.
check for
1 restricted drain system.
2 kinked/plugged drain hose or pump
3 faulty pump
4 loose connections on the board or pump
if you find none of the above you have a faulty control board.
hopefully you just find something clogging the pump, remove the pump completely and make sure it is not a paperclip or something like that down in the pump jamming it up so it doesn't drain, be careful and get lots of towels because there will be water in pump system.
Here is the board to order in case you find that it is the problem.
Sep 26, 2013 | Maytag MAH2400A Front Load Washer
Washer stoped and did not finish rinse cycle now it makes a humming sound and code nd
Washer Error Codes ND IS -No Drain There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken
  1. Unplug the washer from the electric outlet.
  2. 3Open the case, and disconnect the water hose from the outlet of the water pump.
  3. 4If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  4. 5Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  5. 6Reassemble hose from step 3.
  6. 7Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  7. 8Reassemble washing machine case...you're done...
Oct 11, 2011 | Washing Machines
Nd on washer
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Shows code nd washer only hums when restarted and door will not open
Hello,"nd" refers to a No Drain issue . check for restriction in pump assy, restricted drain hose loose wire at pump, bad pump.
Thanks
May 31, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
My washer shows the error code nd and will not finish the wash cycle
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 13, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
