When I try to call any number an info apeears with the resd STOP sign saying call rejected and I tried to call to my mobile with another but no incoming calls as well. Network is full. But no access of the network cannot even divert calls. I thought it would be the problem of the sim but I was shocked when I insert the sim into other set. It worked normal! Now I am so much depresed what to do with it. Plz help me to solve this problem.plzzzzzzzzzzzzz.
Go into the phone system settings...there should be an option that allows you to modify what calls you can make/receive. change them to allow all calls
in your phone settings menu, there should be an option that says security. it may prompt you for your security code, which is the last 4 of your number unless you've changed it. once in that menu, look for an option that says restrictions or something like that...
Since you have no access to the network, you'll need to take it to your service provider and have them look at it. sounds like an internal antenna problem possibly.
In Menu mode, select Settings → Application
settings → Call → All calls → Auto reject and turn auto reject off. This will allow all calls to reach your mobile.
no such option found plz help
thanks. but in my phone settings there r language,light,memory status, and else. and in security settings there r PIN code request,Call barring service (but when I try to cancel all barring it says that request not ompleted),Fixed dialing, Closed user group,Security Level,Access Code and Code In Use. thats all are the options in my Nokia 3220. I m not having any access of the network that is the main problem as far as I realized.
