Question about Motorola Mobility H500 Wireless Headset
Computer won't recognize my headset
My computer won't find my headset... i've gone through many steps found in forums to try to fix it, and i have the latest driver installed, but it always shows red and no headset is listed
  • 2 more comments
  • luckycj70 Oct 22, 2007
    sorry, it's a motorola h500
    do you mean antenna? just the one that comes with the headset
    hmm, yes i think the problem is i can't open my bluetooth places or the bluetooth wizard, so my headset is not pairing. for some reason it won't open
    i did reboot, the bluetooth won't open... earlier i removed the MS bluetooth device from the device manager, realizing afterward that i was only supposed to disable it, but i also can't seem to do a system restore for some reason.
    the bluetooth is external, usb...
I gona b connect h500 but my HP laptop said no driver installed
Posted on Nov 23, 2010
  • 104 Answers
What blue tooth atenia are you using on your computer?
Posted on Oct 22, 2007
  • 1 more comment
  • Lou Labetti
    Lou Labetti Oct 22, 2007
    no-no, the one that is connected to the computer. Let me explain You first have to put the headset in "pairing" mode. Then on your computer you need a blue tooth antenna and software so you can tell the computer to "pair" with the headset. That headset also has a preset password of 0000 . What I am asking is "what do you have set on your computer"?
  • Lou Labetti
    OK so we need to look at the computer. Is your Blue Tooth internal (within the case) of the computer or is it external (connected via a usb or firewire port) ?
    BTW - Please reboot your computer to reset your software to see if you could open the blue tooth wizard
  • Lou Labetti
    OK what is the manufacture of the external blue tooth adapter?
    You should have a cd (software) that would have that adapters drive as well as a "blue tooth wizard" software.
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Why won't my motorola finiti connect to my PS3?
I'm having this problem and need help please for my 12 yeatr old son
Jun 10, 2012 | Motorola Mobility FINITI Headset
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
My headphones work, my mic does not(at all)
Have you gone to your control panel, and found the "speech recognition" option? If you havent tried it, do that. It wil have you recite a sentence and then should conifgure your mic to your computer. I hope this helps!
May 30, 2009 | Logitech ClearChat Style Headset Headset
Motorola Bluetooth Headset H700
Have you gone through the "pairing" steps to get the phone and H700 unit to recognize each other? Unless the two are paired with each other they won't communicate with each other.
Jul 06, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
868 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
