Question about Lanier Office Equipment & Supplies
Lanier 6725 need pm code or manual
Error code a2 i bought a lanier 6725 and do not have a manual for it . i was told i need a pm code to reset it . does anyone have this code> or how can i get a manual for this machine?
    Novelist:
  • 158 Answers
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
Posted on Jun 22, 2009
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Hi have a lanier copier model 6725. When I make copies it makes the copy and then also prints grey across the entire copy. Looks like it is printing old ghost copies...how can I fix this
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Sep 02, 2011 | Lanier 1205 Copier
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Lanier 6725
If you open the duplexer cover, you will see a photo interupt sensor on the right. Stick a piece of paper in it. Take the waste bottle out, so you can see the inside of the duplexer. Turn the machine on. A minimal amount of waste toner will fall, and can be easily cleaned up. There are two stacker guides in the duplexer. One stacks lengthwise, the other widthwise. If memory serves me correctly, the horizontal guide not moving, or the sensor not sensing movement causes that error. If the guide moves, the sensor is probably dirty or bad.
Mar 18, 2008 | Office Equipment & Supplies
LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Feb 11, 2008 | Office Equipment & Supplies
Lanier 6725 service code A4
You have a problem with your sorter. Unplug it, and it will go away. The sorter has an initialization problem, but A$ is a very vague code.
Jan 14, 2008 | Office Equipment & Supplies
279 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
