Question about Jandy Lite2 LG400 Ceramic Compact Heater
Pilot will lite but burners will not kick on - Jandy lite 2 400,000BTU pool heater Me too.. was able to fire it up by tinkering with the switch that goes from "Pilot" to "On", but doesn't always work. A technician recommended removing some of the wires and cleaning the wire ends and terminals with steel wool as condensation gets in there sometimes over the winter. I have no clue which wires to do this to - I haven't tried this yet - do at your own risk!
  • 1 more comment
  • dbehman Jun 01, 2009
    Thanks for post - however, my pilot does NOT go out - it stays lit all the time. I only moved the main gas valve from ON to PILOT in my tinkering around to get things working - it was not because the pilot had gone out. As I say, oddly enough one time when I did move it to PILOT and then back to ON, the main burners fired up right away. I've since tried that about 10 times with no success.
    Any other suggestions?
    Thanks again.
  • dbehman Jun 11, 2009
    Hi co7196 - thanks very much for following up!
    My father in-law (who is more handy with this stuff than I am, but still far from a technician) came over last week and tinkered with the heater for me. He told me that all he did was remove the wires one at a time and cleaned the terminals and the wire ends then put them back on. Ever since then the heater has fired up without a problem!!
    However, it now seems as though the thermostat is more sensitive. What I mean is that when I barely got it working several weeks ago, the thermostat dial (not a digital panel unfortunately) was set to about 2 o'clock and was butted up against a stopper to prevent it from going higher. It would then kick off at about 88 degrees which I thought was perfect. After my father-in-law tinkered, the pool got up to about 95 degrees before I realized that the heater now wasn't kicking off! If I turned the dial back to about 12 o'clock it seems now to kick off at about 90 degrees there.
    So perhaps by cleaning the wires and terminals, more of a signal is allowed to come through and the dial is actually now more correct?
    Thanks Ned! No need to apologize - its hard to fully diagnose a problem like this through the internet. :) I'm cautious about monkeying with wires and such anyway (one of the reasons why I let my father-in-law do it).
    Using silicone on the contacts is a great idea - I will try that. Thanks again!
    President:
  • 3,433 Answers
No, do not mess with wiring. If the gas does not ignite and the pilot goes out, The thermocoupler is faulty. This is the probe that should be sitting at the tip of the pilot flame. When it gets hot enough it allows the main gas valve to open when you put it to ON position. If the pilot light goes out, It shuts off the gas for safety. Summary, Bad thermocoupler. Easy, inexpesive repair. Let me know please, if you need further help.
Posted on Jun 01, 2009
  • 1 more comment
  • Ned C Cook
    Ned C Cook Jun 02, 2009
    It still points to the thermocoupler. It's the boss of everything for safety reasons. Failure default is Nothing fuel stoppage to main burner. They don't cost much but can drive you nuts.
  • Ned C Cook
    Ned C Cook Jun 11, 2009
    Hello, Did you get your problem solved?
  • Ned C Cook
    As long as you got it working, that's the important part. It appears there aren't any markings to indicacte the remp setting. You turn the dial and watch the thermometer? If thats the case you may want to get the temp where you want it and mark the dial or its housing so setting it would be easier. Yes, the signal is cleaner now since your father in law took care of it. please accept my apology for telling you not to mess with the wiring. Just before my attempt to help you, i assisted someone who was told to do some wiring work and he ended up with a rats nest in his efforts . He also got too close to high voltage and didn't know the hazards of poking and pushing on relays with a screw drive. So trust me, it was only my preference you were forced into having someone on site to assist you. If this would help, I'd like to make a suggestion that would help keep your problem from reoccuring. Get a tube of clear silicone snd cover those terminals that had to be cleaned. It will stopmoisture and corrosion. Well, all is up and running and that's want counts. Enjoy. - Ned
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Laars lite 2 pilot stays lit but burner will not fire
make sure pressure switch tube is not plugged see if both sides of pressure switch have 500 milliamps make sure gas is on
May 20, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not light main burner
make sure pressure switch is ok and the safety circuit if ok you might have a loose wire also check for cob webs
Jun 30, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Feb 15, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite2 LG400 Ceramic Compact Heater Logo
688 people viewed this question
Top Jandy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
