Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-57ws500 Alright so I have a couple problems that I am really needing fixed. First what board should I replace when I get the seven blink code error? or is there anything i should check and see to replace first. Second the cap off one of the guns came off and leaked coolant, I dont believe it leaked onto the board BUT if it did it only leaked on it a little, where would be the best place to buy coolant, because i dont want to start it up without that in there? I am begging for help here cause I would really like to get it running again!
  • 11 more comments
  • NCT Oct 22, 2007
    sorry one more question I think its the D board so should I completely replace it or should i just try and repair the chips that are already on it?
  • NCT Oct 22, 2007
    Hey what is a g-bd ?
  • NCT Oct 22, 2007
    No i dont believe my tv has it I could take a picture and give it to you and you could tell me if you saw it?
    But i do have a couple other things I really wanted to know,
    Is there anything other then the g board or the D board that the seven blink code could be?
    If I do have burnt out chips on the d board is it possible to fix it or do I have to buy a whole new board?
    The person i got it from said it had two burnt out chips on the power board so how would he know which ones were burnt?
    And lastly the top plastic part came of the right gun and doesnt have any fluid left thank god non spilled on the board BUT i was wondering what would be the best way to seal it back up ( cause i heard they were sealed at sony)????
    I really want to get this fixed ASAP! thanks
  • NCT Oct 22, 2007
    Hey thank you I will look for them and yes i am really good at soldering.
    I was also wondering if you had a diagram because I read on a tech site that it most likely is q8035 and 8036 but i can NOT find them on the board, do you know where they might be?
  • NCT Oct 22, 2007
    Also I looked at it again and yes i have the G board so what could be my problem?
  • NCT Oct 22, 2007
    Ok so I found the q8038 and the other one but how do i know which board to replace or repair?
  • NCT Oct 22, 2007
    also the circuits on the D board look good they dont look like they have failed or are burnt but that may mean nothing.
  • NCT Oct 23, 2007
    So if i replace the d board all together then that should fix the problem?
  • NCT Oct 23, 2007
    Ok so I know for sure the fluid did not leak anywhere on the board, So how would I go about locating the fried cirucits to replace them? or would it be better to just replace the whole d board? (cause i would much rather buy the circuits.)
    And one more thing ( i know sorry) one of the red wires came out of the top thing with the four red wires I put it back in what else should i do with that?
    Btw thanks for all the help.
  • NCT Oct 28, 2007
    Alright so the tv Blinks 11 times then shuts off what does that mean because I looked up the blink codes and they only go up to 10. please help!?
  • NCT Oct 29, 2007
    Yeah I replaced the D board, it went very smoothly, Have not gotten around to the crt but what happened was someone just took the cap off so undid three screws and put it back. (after refilling it with fluid).
  • NCT Oct 30, 2007
    I need help in ordering the part
    Would this http://www.partstore.com/Part/Sony/Sony/...
    Be everything that is in the picture here...
    http://photobucket.com" target="_blank">http://i55.photobucket.com/albums/g142/S..." border="0" alt="Photo Sharing and Video Hosting at Photobucket">
    I am looking for everything that is circled thats already together.
    So if thats not the right thing to order what part should I look for?
  • NCT Nov 08, 2007
    Hey I found a KP-51WS500 and I was wondering if the parts were interchangeable with a kp57ws500?
  • 59 Answers
You can get coolant at a electronics part store if there is one in your area, does that tv have a g-bd on the left side looking from the back?  that also might be your 7- blink problem
Posted on Oct 22, 2007
  • 5 more comments
  • tvray Oct 22, 2007
    G-board is part of the power supply, small bd on left hand side looking from back about 8x10 not sure if your tv has it would have to look at schematic. let me know if you want me to get more info
    yes the crt is sealed you would have to buy a new one about $200.00. i am surprized none leaked on the board there is quite a bit of fluid in those, if you are good at soldering you could repace those chips if you know which one they are. it is common for the convergance amps to go bad, they are locatted on the large heatsink the number on the chips start with stk-
    well your flyback my be shorted or much more if the fluid leaked anywhere on that bd, you can send that d-bd in to pts electronics they do good work and at a good price. forget what i said about G-bd that is only 3-blinks
  • tvray Oct 23, 2007
    don't forget the crt with no fluid
  • tvray Oct 24, 2007
    you can try andrews electronics they have a web site but you need to know the part numbers you want, and that red wire should just push in and lock that is where high voltage goes to the crt's
  • tvray Oct 29, 2007
    have you done anything to it sofar?
  • tvray Oct 31, 2007
     you would order the crt the yoke and crt bd all separate
SOURCE:
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Oct 05, 2008 | Sony KP-57WS500 57" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
you need a new green CRT, sony has had some problems with the green and blue crts developing shorts . Let me know if you need further assistance.
May 09, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
