Question about GE Refrigerators
Fridge warm at top cold at bottom
I have a GE GSS20IEMB WW that is very cold at the bottom of the fridg and freezer but warm at the top of both. I have replaced the evaporator fan and the defrost element. The defrost element is now working but the fan isn't kicking on and I still have the even temp problem. what do i do next?
  • GE Master
  • 4,654 Answers
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
Posted on May 29, 2009
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer freezing ......top not cold
Verify the fridge "flap" which could be stuck closed. To do this remove the shelves and then remove screws holding the center panel (3 screws for a bottom freezer). At the bottom you will find a connector which can be unclipped so you can take the panel out completely from the fridge. See if the flap is closed if it is then that could be the problem. It may need to be replaced. Good luck.
May 10, 2009 | GE GBS18HBR Bottom Freezer Refrigerator
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
1,317 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
