Question about Marshall 15 Watt Guitar Amp
No sound through marshall amp even though i can get sound through the P.A if running from the amp
  • Michial Gueffroy May 11, 2010
    Is your Marshall one of those with the control for the line out volume? I can't remember the model but my friend had one and couldn't get any volume until we realized that particular pot was turned down. It was on the extreme right hand side on his amp. I don't know if this helps or not. Sorry.
    Scholar:
  • 109 Answers
The best thing would be to take it to an audio repair tech. Could be anything....Not something you can fix without taking apart and using a multimeter.
Posted on Jun 18, 2009
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Aug 06, 2012 | Marshall Amplification Marshall MG15FX...
Hello, well i just bought this week an MB4410 marshall and it sounds a lil bit distored even at low volumes and on the clean modern channel, i just wanted to know if thats how the amp should sound like or...
First make sure your guitar can't "hear" the amp as the sound can rattle the strings and have a form of feedback. Stand with your back toward the amp for example. If that doesn't help, take your guitar to the dealer and try it on another of the same type... see if it does the same. Also where you use it, make sure nothing is rattling in the area that can fool you as to how it sounds...
Apr 10, 2011 | Marshall MB4410 Bass Combo Amplifier
I have an MG30 FX amp. In manual mode when I change channels amp seems to work incorrectly. E.g. i select clean, then set up delay. When I change to crunch then, there's no delay, though from the manual I...
Typically ONLY one effect will be active at a time unless there is a specific mixed effect available. The gain levels between the different effects are often not too consistent. In summation, this is probably the nature of the beast.
Mar 12, 2011 | Marshall Amplification Marshall MG4 Series...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I can turn it on and i hear the fan going...but it doesnt make any sound when i strum or anything...please help!
There are some basic things you can try before you suspect the amp. Does your guitar cord work in another amp? Is your guitar sending sound through your guitar cord? Without any thing plugged into your amp can you hear a slight hiss when you turn your controls up on your amp? Here is a link to some things you can do to troubleshoot the problem:http://www.geofex.com/ampdbug/ampdebug.htm Even though the info is for tube amps a lot of it also applies to solid state (transistor) amps like yours.If it turns out to be the amp and you don't feel comfortable working on it and have no one that you know personally to do it you are best served by taking it to a certified Marshall repairman who will have the tools, parts and schematics to help you.
Apr 18, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall DSL 401 runs fine for about 10 minutes from cold then starts to crackle and sound disappears The amp is fairly new with not a lot of use
if this a tube amp then your tubes might be going bad. but if it is a solid state amp then im not to sure whats going on.
Mar 01, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall 15 Watt Guitar Amp Logo
667 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
