Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Belive timmer being set
Tv turns it self on and off remote can not work to change tv
TV sound changes by its self goes to 100 or 0 randomly remote won't work
2 questions.
1. Do any of the remote functions work, IE. channel selector, settings menu etc.?
2. How old is the TV?
Several possibilities come to mind;
The remote battery is low.
The remote sound function may be faulty( bad button switch) this is usually a matter of how much the sound switch is used.
The automatic volume control in the TV has failed. This sounds like the best possibility. Once set, the sound should maintain its level. If not, the the AVC is dead and you will probably have to get the TV assessed by a tech. If this is the problem, you might consider a new TV. Tech service is expensive and in many cases it costs so much to fix a relatively simple problem, that buying a new unit is easier and more economical.
Aug 01, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Tv is locked and wont turn on. i have no remote
Hello
If RCA tv has locked accedently and you haven't its original remote handset it is almost impossible to unlock it. Just try to get its original remote control from any of your friends or relatives who owns the same model of RCA set, borrow it from them for just unlock your set and try the following tricks. One amoung them will surely unlock your RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
May 15, 2011 | RCA 24F512T 24" TV
Turn on the tv and it comes up with a password entry,do not have a password and i can not get any of the buttons to do anything also do not have remote
hi,
u have to reset the v chip setup of ur tv. read the following and choose one which suits u.
ok
Jan 08, 2011 | RCA TruFlat 27F520T 27" TV
I LOCKED MY RCA TRUE FLAT TELEVISION AND IT WAS TURNED OFF MY QUESTION IS; HOW DO I TURN THE T.V. BACK ON?
Hello
OK.
Dec 17, 2010 | RCA TruFlat 27F520T 27" TV
Timer keeps going off
push in timmer knob turn till its at 12 o clock if it does not shut off then the timmer is bad ..you can dissconnect timmer from the back ..turn off breaker or unplugg. dissconnect wires from timmer .. tape connectors real good .now no annoying buzz
Aug 22, 2010 | General Electric Stove/Oven/Range Chrome...
When i push the on button tv turns on or makes clicking sound timmer light flashes and turn off. another thing is when i push device on remote or tv the tv turns off or screen turns blue then shuts off
I would start by pressing the reset button on the front of the screen. After you are able to turn the tv on, press menu the 2470 then press enter on the remote to reset the tv. This might fix your problem. If not suspect the E2P, and if that doesn't work your DM is faulty and needs replaced.
Jul 06, 2010 | Mitsubishi WD73727 73" HDTV
My remote won't allow me to turn on our TV but after I turn the TV on, the remote allows me to change the volume and mute but will not allow me to change channels.
I would re-program the remote. I don't belive this is the exact correct code. Some codes kinda work but no fully. That's when it's time for another code for your brand or use the setup and power auto-code search
Apr 08, 2010 | Philips Televison & Video
Need 4 digit password for rca tv 2003
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Sep 29, 2009 | Televison & Video
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
