Question about Hunter Dryers
Hunter ceiling fan(French Quarter model) remote
When using my fan at night (with the remote) the fan sometimes changes speed on it's own or the light comes on in the middle of the night. What's going on?
    President:
  • 1,489 Answers
The fan receiver is receiving signals of the proper frequency from sources other than your remote. This is very common. Could even be your neighbors remote...if you have neighbors...
If it's a real problem for you, you could try changing the frequency on your units (see owner's manual) -- that might help, or it might make it worse.
Posted on May 28, 2009
Hunter "French quarter " ceiling fan stops without being required to. Lights operate on or off without being required to.
loose wire connection White wire is neutral black wire fan blue wire lights. Since the light and fan are both affected that indicates the white wire is loose at the power panel or at the top area of the fan assembly.
Jun 15, 2015 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
How can I fix this with fan and light turns on without remote
This might be a silly question but have you tried takeing the batteries out of the remote?
Jul 26, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Magic fan
Sounds like a defective infrared sensor in the fan. I assume you have tried removing the batteries in the remote to rule out the remote. I don't think you have a wiring issue....your light works and the fan works. Typical fan wiring involves the fan & lights. The wiring for the infrared should already be wired from the factory. Its in the infrared detection circuit.
- Jim
Feb 12, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Dryers Logo
432 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
