Question about Kenmore 80809 Microwave Oven
Kenmore microwave 721.80593402 died
The gadget is about 3 year old. Went off out of the blue after starting cooking. Burnt fuse replaced, all the lights came on, but when started cooking, the whole unit died again (tried twice) . What could that be? How can I get it fixed? My Kenmore Elite Microwave at first would not work at all after plugging it into the wall. I took it apart and put in a new fuse, then when I plugged it in the wall, it gave power and prompted me to enter the clock information, etc. Then, whenever I press the start button on the unit, the circuit breaker immediately pops, but the fuse is still okay. Do you know what might be wrong with the microwave or what needs to be replaced? Obviously, something is shorted...
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave 721.80593402 died
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find exploded views and order parts by entering your model number here: http://www.searspartsdirect.com
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Just went dead. checked outlet for power has power to machine
yes most microwaves today have a fuse in them it looks like the old glass fuse but not made of glass, instead they are of a gray look and ceramic. If I remember well Radio shack sells them
Apr 04, 2009 | Microwave Ovens
Kenmore microware does not heat
It's one or more of the following items -
Fuse
Diode
Capacitor
Transformer
Magnetron
Yes, you can fix the unit, and I can give you direction, but make sure the microwave circuit is not covered under a longer term warranty.
Feb 01, 2009 | Kenmore Microwave Ovens
Jul 09, 2008 | Kenmore 80809 Microwave Oven
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
My microwave died
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 20, 2007 | Panasonic NN-S251 Microwave Oven
Kenmore 80809 Microwave Oven Logo
150 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
