Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
No water The handle of my single moen shower faucet appears to be loose and when rotated to turn on the shower, no water comes out. I don't know where to start to try to fix it. There appears to be a screw inside the handle, but it has a different kind of head of it and I can't get it to turn. Please help!
  • 67 Answers
Moens push and pull for water flow and turn for temp are you pulling and turning or just trying to turn, the handle should indeed have a standard phillips screw head
Posted on Jul 10, 2009
    Problem Solver:
  • 13 Answers
The screw should be a phillips head or allen screw
Posted on May 28, 2009
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
My Moen Tub and Shower have water coming out of both the tub and shower when I turn on the tub.
Take the handle back off and rotate the stem one half turn clockwise and put the handle back on.
You'll be good to go!
Mar 05, 2011 | Moen & One Handle Tub & Shower Faucet
I have a single handle shower faucet (new) and when i turn it on , no water comes out
This may sound rather obvious but after the shower faucet was installed did the supply lines get turned back on?
Jun 13, 2010 | Moen 1 Handle Lever Shower Faucet With...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
280 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
