Question about Beverage-Air Beverage Air 2- Tap Unit Model DD78 - Stainless Steel
Beverage air dd78 comp.wont start..tripping GFI
As soon as i plug the unit in it trips the GFI outlet, I narrowed it down to the compressor side, what is the most likely problem compressor or relay??
any help is appreciated.
  • 122 Answers
The "compressor side" probably consists of the compressor and condenser fan. One, or both of those could be grounded out. Try testing continuity to ground with an electric meter on both parts, if your handy with a meter. Remove relay and overload from compressor and check all three compressor pins to ground on unit. Check from each pin to the copper tubing. You should not read any continuity. If you do the compressor is grounded. :(
Posted on Sep 23, 2009
    Scholar:
  • 81 Answers
Refrigerators often will trip the gfi via the compressor. If you have checked all the wiring. The problem is likely in the compressor windings. I have had this occur in brand new units. Another thing to check the gfi, less expensive gfi outlets do not handle refrigeration equipment well. You should consider getting an industrial rated outlet. Hope this helps.
Posted on May 02, 2009
  • Try to plug the unit in to a non-GFI outlet. If the unit works, you could try to find an industrial strength GFI, these are far better than the standard GFI. This may remedy your problem. I have seen many units brand new that will trip a standard GFI. Hope this helps. If this does not help a new compressor may be in order. The new GFI is worth a try considering the cost of a new compressor.
  • Beverage-Air Master
  • 1,266 Answers
GFI's are sooo touchy. I would try running the unit while plugged into a standard receptical. If that works, change the GFI. If not, look farther into the compressor side. Start components, compressor, condenser fan.
hope this helps and let me know if I can be of any further help
Posted on Jul 11, 2010
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
Used Beverage-air MT27, trips GFI breaker when I plug it in. I tried to isolate the short - unlplugged the top light ballast, switch, fans... The guy I got it from says to be sure to connect the ground...
I've seen refrigerators that are working fine blow GFI outlets when the compressor starts, usually just change to non GFI outlet for fix. You say its tripping GFI breaker , is there anyway to test it on non GFI breaker?
Jun 24, 2011 | Beverage-Air MT27 Beverage Cooler...
My refrigerator keeps tripping my gfi out let.
This is a problem I have encountered before. When compressors start they sometimes trip gfi. Plug unit in different outlet or replace GFI with regular outlet
Jun 22, 2011 | GE Refrigerators
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
10 year old air compressor cuts off at 10psi
hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Hotpoint refrig 21 cf over and under
Of course it can be plugged into a GFI outlet. Sounds like you have a compressor problem.
Nov 24, 2008 | Hotpoint HSS25GFP Side by Side...
Restriction
The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Beverage-Air Beverage Air 2- Tap Unit Model DD78 - Stainless Steel Logo
431 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
