Question about Zyxel Prestige 320W Wireless Firewall Router
I don't know much about computer. my desktop runs great, but my laptop can't find a connection
My ZyXEL works fine on the desktop, but on my laptop it can't find a connection
  • John Moore May 11, 2010
    What is ZyXEL and what is your laptop?
  • 556 Answers
SOURCE: ZyXEL Wireless set up.
First many current PC models have switches to power on the wireless feature. Do you have one of those and did you power on the wireless.
Second wireless devices communicate on four different bands A, B, G, N. Some devices support multiple bands. Does your wireless router/access point (maybe a Zytel p660HW-D1 from above) support at least one of same bands as your laptop built-in or purchased wireless adapter? If you do not know post the manufacturer of the wireless router/access point, laptop if the wireless is built-in or wireless adapter if it is a separate device and I will check that for you.
Posted on Dec 26, 2007
SOURCE: zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Posted on Jan 11, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
megax01
  • 50 Answers
SOURCE: my zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
Posted on Jan 19, 2009
2Gigs
  • 141 Answers
SOURCE: unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Posted on Feb 23, 2009
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
ZyXeL P320W Won't connect to internet
check weather urwireless zero configuration is disable go to the my computer right in that manage in the manage go to the services in that go to the services in that one service is there in down wireless zero configuration just start it if already start just go for the restart
Mar 28, 2009 | Zyxel Prestige 320W Wireless Firewall...
Unable to connect my wifi laptop to my existing wireless b/band
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Jan 01, 2008 | Zyxel P660HW-D1 Router
Zyxel will not connect to my laptop wirelessly
Step 1 - If your laptop contains an ethernet port for a wired connection -- connect it to the router using a wire. Try to use the internet -- if it works we are assured the router to the internet is correct.
Question 1 - Please respond to this with the make and model of your laptop and if you have one the make and model of wireless adapter for use with the computer.
Question 2 - Was this router originally purchased new or used?
Question 3 - Has this router work wirirelessly with any other computer you know about?
Question 4 - Have you configured this router since you got it?
Question 5 - Have you had someone else configure this router since you got it?
Dec 07, 2007 | Zyxel Prestige P-330W Wireless Router...
Zyxel Prestige 320W Wireless Firewall Router  Logo
81 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
