Question about Amana AMV5206AAS Microwave Oven
The bulb blew out i took the old one out and it broke it broke when itook it out, and i hit the the pin and it flashed now i do not get any power, is there a reset on it
    Problem Solver:
  • 13 Answers
Did you check your breakers?
Posted on May 28, 2009
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
LG light bulbs
The part number you need is 6912W1Z004B. You can this part at repairclinic.com for about $4 each. I hope this helps you.
Dec 22, 2008 | LG LMV1925 Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic chef microwave mcd153 uw 1000 watt output
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 22, 2008 | Microwave Ovens
Microwave went completely dead after changing bulb-
Nom...you probably blew the internal fuse. This time...turn off the power. Remove the button panel and search for the blown fuse. It might be ceramic or of some other type. If on a circuit board, there will be a xxxA with xxx indicating the amperage. Use a multitester available at Ace or Radio Shack to test. Replace with the same kind of unit. Your local auto store, appliance parts guy, Radio Shack or Sears parts can get you the part you need. Show them the old one.
Dec 17, 2007 | Whirlpool MH3185XP Microwave Oven
Amana AMV5206AAS Microwave Oven Logo
67 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
