Question about Palm Z22 Handheld
Touch screen works intermittantly??
I have reset the device, also powered it on and off and it will work with the stylus and then it stops.
    Sergeant:
  • 452 Answers
Might be infected with virus so scan it with antivirus if ur h set is having memo. card then try to turn it on with mms card or for more suport contact service centre
Posted on Oct 22, 2007
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
HTC TOUCH HANG WHEN I BOOT
Dear mate try to reset your phone hard i.e"Hard Reset",
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default,
Release the TALK and END buttons, and then press ENTER on your device.
Jan 27, 2013 | HTC Touch P3450 Smartphone
Touch screen not working. mobile getting automatically restarted time to time.
It needs a reset.
This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after theinstallation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
Hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost.
To perform a hard reset
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Aug 03, 2010 | HTC Touch P3450 Smartphone
How do you fix a touch screen that does not respond? I have done a complete reset and still nothing. Thanks.
Have you already performed a clean reset? You might know that it will restore your device to its factory settings, thus deleting everything you have installed, as well as your personal data and settings. So, it is strongly recommended to backup your data beforehand.
Anyway, to perform a clean reset, press and hold the Calendar, Power, and Messaging buttons, and, whilst keeping them pressed, press and hold the reset pin with the stylus pen. When your device restarts, release the buttons and the stylus pen from the reset pin.
Hope it works for you.
Cheers! Carlos
May 12, 2010 | HP iPAQ hx2410 Pocket PC
Iam sooraj using HTC P400i PHONE MY MOBILE NUMBER +919946324460(PREPAID VODAFONE) I CANNOT USE GPRS IN MY MOBLIE PLS HELP TO BROWSE BY GIVING MANUUAL SETTINGS
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  2. On the System tab, tap Clear Storage.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch P3450 Smartphone
How do i hard reset the htc p4600?
  2. Turn device OFF.
Sep 29, 2009 | HTC Touch Diamond Smartphone
Program page not working in Windows Mobile on HTC Diamond
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Jan 27, 2009 | HTC Touch Diamond Smartphone
HP iPAQ HW6915 Mobile Messenger
Do you try the hard reset? Is the screen white?
Sep 19, 2008 | HP iPAQ hw6945 Smartphone
Screen not responding to stylus
SOLUTION:
KEEP PRESING CALENDAR+MAIL+POWER BUTTON
AND INSERT STYLUS IN RESET BUTTON
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
Palm Z22 Handheld Logo
57 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
