This is normal. Countertop dishwashers have two motors inside. The drain motor is a inductive type motor. They are noisy. They all work this way during draining.
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
I doubt that the user manual covers de-liming the Hobart Dishwasher.
If I owned this (fine, expensive) dishwasher, this is what I would do.
1.) Discard any generic, ultra-cheap detergent. Stop using gels or tablets and only use powders. Buy a box of brand name powder (like Electrosol or Cascade) You will be amazed how much difference that will make because the newest generics have mineral bulk added that build up faster then hard water does on both the stainless steel enclosure plus the silverware and even plates. White patches. I LOVE generic products and saving money, but low end dishwasher powder is one place I no longer choose a generic product.
2.) Add two cups of white vinegar to the empty dishwasher and leave it there until the morning. Run a quick cycle with no detergent added. The vinegar will be pumped out immediately after you begin this quick cycle.
3.) As soon as the dishwasher fills with water during that quick cycle and begins a wash cycle, add two cups of white vinegar and close the door and allow to run the full wash cycle.
4.) When the dishwasher finishes the drain cycle and begins to fill again, open the dishwasher and check the enclosure for remaining "lime" deposits. If they remain, keep adding 2 cups white vinegar each time the dishwasher refills and begins to wash/rinse again.
You should be delighted with the results. Long term, you should consider adding a whole house water softener and then reduce the amount of dishwasher (and laundry) detergent by one half. Amazing increase in quality of life by adding a water softener. You will be delighted.
Please post back with you results, OK? Good Luck!
Heat that is retained in the dishes is largely responsible for drying
in this dishwasher. Since plastics do not retain heat very well, they
will not dry as well as glasses, ceramics or metal dishes. Rinse aid
must be used so that the final rinse water will sheen off of the dishes
to accommodate this drying process. The heater element at the bottom of
the tub is used to add heat during the drying cycle to aid in this
process as well. This model of dishwasher does not have any forced air
circulation system. Here are some tips that may help you resolve your
drying problem:
Make sure that you are using rinse
aid. Failure to properly use rinse aid can prevent proper drying.
Adjust the amount that is dispensed if necessary. Also, check to make
sure that rinse aid level decreases over time indicating that it is
being dispensed properly.
The NORMAL WASH and POT & PANS
cycles heat the final rinse water up to 140 degrees F. Use these cycles
to help the drying process.
Do not choose the air dry option.
This option cuts off the heater element during the drying process.
NOTE: The heater element is not turned on during the first 6 minutes of
the drying portion of the cycle.
Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is
not working, the control will detect the lack of increase in water
temperature. The dishwasher will stop and the CLEAN light will blink
seven times repeatedly. The dishwasher would not be able to be used
until the problem is corrected and the control is reset.
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
