Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do i align my printer, it's printing blurry but copies fine
How do i align my printer, it's printing copies fine ,but prints text blurry
  • 526 Answers
The problem is with the main board. I fixed two of the exact same problem before.
Posted on May 28, 2009
Black text printing blurry
if new take it back for a warranty check / exchange or refund
Nov 30, 2016 | Office Equipment & Supplies
How do I cure blurry printing please?
You don't say what type of printer you have (some have built-in utilities that can guide you to correct things) but generally speaking, if text print is coming out blurry, you may want to look at the following:
1) Check your ink cartridge. Is it dirty? Is it plugged (clogged)? A good cleaning may help by removing your ink cartridge and swabbing the print head nozzle (check your manual for location) with isopropyl alcohol with a cotton Q-tip. Run a test print. Still a problem? You may need to do this about 3 or 4 times before it clears. If your printer head is way down indide the printer, you can get an eye dropper and drop some isopropyl alcohol on it.
2) Check your quality settings. Perhaps someone had changed the settings from "Best Quality," for instance, to "Draft." Make your changes and click Save. Run a test print.
3) Check your paper type. Do you have the right type of paper for your printer? Inkjet printers require inkjet paper, whereas laser printers require laser paper. Mixing the two will produce poor print quality. I am assuming you have normal copy paper in your printer tray, which is fine.
4) Check for printer software updates. Have you tried reinstalling your printer again, especially your printer drivers? If your printer is an older model, perhaps a software update is needed. Go to the manufacturers website and see if there are any new print drivers for your model. Run a test print.
5) Replace your print cartridge. This could simply be an issue of your cartridge being too old, drying up or defective. After installing new cartridge, run a test print.
Hope this helps!
Pen
Aug 14, 2014 | Epson CX9300F/CX9400Fax/DX9400F
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
1,202 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
