Question about Dell (8H390) Sound Card
Yes, there are three yellow question marks NEXT TO EACH STATED BELOW 1.?other devices 2.?ethernet controller 3.?mulitimedia audio controller
  • 90 Answers
Ok that means you need a driver for each of those. You will either have to go to the manufacture website (ex. dell.com) or the motherboard manufacture (if you built it yourself) look up the correct model pc/motherboard and download the drivers for each item (ethernet, multimedia controler). After you run each of the downloads either it will remove the exclamation mark or if not you can right click the item with exclamation and hit "update driver" and click next through all the menus and it should install.
Posted on May 28, 2009
Not working sound
Hi friends,
Uninstall audio driver and restart your PC manually and install the driver again.Hope it will solve the problem. Please check the next steps. To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). Or you can roll back the driver, http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx Or can restore the system. http://vlaurie.com/computers2/Articles/windows7-system-restore.htm For XP http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If you will face in same problem, reset your BIOS.
Please follow the instruction bellow.
Restart
Press Del/F2/F10 right after starting the computer for BIOS setup http://www.computerhope.com/help/phoenixa.htm
You will do enable on board audio device. If you think it is difficultto set please do the
next.
I always suggest to set load fail save default >F 10(F key)>yes. Now installthe driver again. If the problem is same is before please use an USB audiodevice.http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5shibuda_29.jpg
Jan 10, 2011 | Intel D945GCL Motherboard
What is 1- Ethernet controller driver 2- mass storage controller 3- moderm device on high Definition audio bus 4- SM bus controller How to solve it.
Hello.
I guess some computer components refused to work and you found yellow question marks on Device Manager.
So…
1. Ethernet Controller manages communication over computer network
More info on Wikipedia: http://en.wikipedia.org/wiki/Network_interface_card
2. Mass Storage Controller manages storage of large amounts of data (that includes hard disks, floppy disks, flash memory, optical disks, removable and non-removable media, but not RAM)
More info on Wikipedia: http://en.wikipedia.org/wiki/Mass_storage
3. Modern Device on High Definition Audio Bus manages audio that is capable of delivering the features and high-end performance of an add-in audio card
More info on Intel site: http://www.intel.com/design/chipsets/hdaudio.htm
4. SM bus controller is the System Management Bus that is used in personal computers and servers for low-speed system management communications. An SMBus controller is integrated into most Intel chipsets.
More info on Intel site: http://www.intel.com/support/chipsets/sb/cs-013541.htm
You can find all the missing drivers of your Toshiba Satellite A135-S4527 at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1700045&rpn=PSAD0U&modelFilter=A135-S4527&selCategory=3&selFamily=1073768663
Jan 25, 2010 | Toshiba Satellite A135-S4527 Notebook
Yellow runs out after only a few hundred prints and didn't used to
Not sure why you're going through the yellow toner so quickly. You might try pulling it out and shaking it some to re-distribute or loosen the toner inside.
Yes you can override the cartridge out of toner print halted problem. This is located in your User's manual and is stated as:
Replace Supplies feature
The printer has three options for low or exhausted supplies status:
STOP AT OUT (the default setting): The printer continues printing while a print cartridge is low.
When the cartridge is out, the printer cannot print.
STOP AT LOW: The printer pauses until you replace the low cartridge.
OVERRIDE AT OUT: The printer continues printing even after some supplies have run out.
To set the Replace Supplies feature
1.
Press Menu.
2. Press (down arrow) to highlight CONFIGURE DEVICE, and then press (check mark button).
3. Press (down arrow) to highlight SYSTEM SETUP, and then press (check mark button).
4. Press (down arrow) to highlight REPLACE SUPPLIES, and then press (check mark button).
5. Press (down arrow) or (up arrow) to select the appropriate setting, and then press (check mark button) to set the selection.
● If you select OVERRIDE AT OUT and then press (check mark button), a warning message appears. To accept the override, select YES, USE OVERRIDE and press (check mark button), and then set the page limit for the override and press (check mark button).
6. Press Menu to return to the Ready state.
Apr 15, 2009 | HP Color LaserJet 3500 Printer
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
anand_anj2005@hotmail.com
Apr 12, 2009 | Computers & Internet
Missing drivers for a Toshiba Tecra M2 PTM20U-4MP0E701!! Help ME!
I have often done this. Take a flash drive over to the public library. Download the drivers and same them on your flash drive. Bring them back to your machine and save them in a conveinent place i.e. My Documents/your name/drivers. Then reinstall them. In my shop we use what's called a dube device. This allows us to download using a USB port. Not everyone has access to this technolgy. The library should work fine.
Mar 25, 2009 | Toshiba Tecra M2 Notebook
Question Mark in My Device Manager
dear,
pl install 1st chipset dirver from motherboard cd.2nd install vga/video driver,audio driver,ethernet/lan driver.
when require restart pl restart pc.
Feb 28, 2009 | Acer AOpen AW 724 Sound Card
NO SOUND FROM SPEAKERS,ANOTHER PROGRAM USING MY SPEAKERS,GATEWAY COMPUTER
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Oct 05, 2008 | Computers & Internet
Device manager
You need to identify what video card, ethernet card and audio card you got inside your pc, then go to devices' websites and download proper drivers.
If you do not know what devices you have, then you need to go inside your computer and put on google the numbers printed on boards.
If devices are all integrated on mother board then you need to identify motherboard model and download drivers for integrated devices.
Jul 06, 2008 | HP Computers & Internet
Computers & Internet Logo
Alun Cox
