Question about Mtd Products Yard Machines 158CC Tiller
Tiller won't stay running
My tiller won't stay running. We rebuilt the carb, cleaned the fuel line, new gas, new spark plug. It starts for only a second than dies. Thanks Serena
  • Anonymous Mar 17, 2014
    have ry60520 tiller the air purge valve is bad. bypassed cleaned carb when i give it throttle it runs out of gas but when i take return line of and feather the fuel coming out of nipple it runs good with throttle wide open as long as i feather the return nipple. does it have to have the purge valve to moderate return fuel flow?
  • 15 Answers
Hmmmm.....it sounds like restricted fuel flow to me, but explain "rebuilt the carb" so I can get an idea on what you did.
Though it sounds right off like you whooped it good and got the basics.
Right off, go back through the "system", check the fuel flow, check that spark on the plug. Eyeball for any loose wires (E.G., Kill Switch, etc.) that are grounding (you never know!)
Stick to KISS on this one, since it ran before the carb got bad and got rebuilt, it will be one of those things you replaced, rebuilt, or changed. Sometimes, it is the SMALLEST thing......
Posted on May 28, 2009
Tiller will not start, new plug, rebuilt carb,replaced upper oil seal, cleaned exhaust port.
You didn't say if there is a spark. Pull the plug out and hook the wire to it and ground the plug to engine. If there is spark then it is likely a fuel problem. Squirt a little starting fluid or gas in the sparkplug hole before putting the plug in and see if it fires. Pull the fuel line off the carb and check the flow.
Dec 06, 2015 | Garden
Last year I started the tiller and while I was using it it just quit and it wouldn't start again. I replaced the gas and put in a new spark plug and still couldn't get it started.
Did you remove & drain the bowl below the carb. If that doesn't work remove the carb & clean out all ports & passageways. Use non-ethanol gas in the future & remove all fuel at the end of the season including in the carb & fuel lines.
May 11, 2015 | Mtd Craftsman 25cc* 2-Cycle Mini Tiller
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
Ryobi 410 mini tiller w/Walbro WT149A primer bulb won't prime. New bulb, new fuel lines, hooked up right, carb cleaned. Been sitting for several years.Runs when fuel is pumped into the fuel inlet.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 21, 2012 | Garden
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Huskee Rear tine tiller
-How about spark plug...? Did you change as well...?
-Make sure turn on the gas line.
-Try again.
Good luck. It's closed for garden time.
Mai
Jan 08, 2018 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
My tiller 917 299440 won't start. It has new gas,
check to see if there is spark. if there is spark then spray some carb cleaner in the carb to see if it statrs if it does check fuel lines and gas filter if there is one
May 13, 2010 | Garden
Yard machine tiller won't stay started!
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
Nov 06, 2008 | Garden
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
717 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
