Question about Systemax Arrival (036063) PC Desktop
Accedentaly remove wires from mother board to front usb ports
Syx p4-036063
I was checking cables from flopy to mother board and I accedentaly removed the 7 individule wiresito motherboard that go to the usb ports in front of computer. would you know what order the go back
Thank Howard Rotz
    Genius:
  • 1,601 Answers
You need to go and get a manual from the manufacturer to find it
Posted on Oct 22, 2007
I have hp laser jet 1020 printer., when i provide print command all commands are showing in different language which i can"t understand
Called "Junk Print"...Check USB cable, Check USB port dry solder mounted on printer mother board., remove & re-fix farmatter board.. If not solved replace formatter board. If ur technically sound replace USB port mounted on board..
See the image farmatter P/No: CB409-60001
Feb 27, 2015 | HP LaserJet 1020 Printer
My acer aspire 5733Z-4851 donot read usb
That could be a problem with the USB connection on your motherboard. This is not a big issue, if you can you just open up your CPU and locate the USB connection on the motherboard. It is not clear to me whether it is the USB ports from the front panel or it is the USB ports that are on-board (usually found at the back). If it is the USB ports from the back, the one built - in on the board, then the BIOS has to be configured again to enable Plug and Play attributes. If the ports are from front then you need to follow the cable that connects the usb port to the mother board. Disconnect and reconnect. Or check whether it is actually connected to the right port on the motherboard. Usually it is written on the motherboard.
Jun 11, 2012 | Acer Aspire 5733z-4851
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I am not getting display. why?
Jan 23, 2011 | Asrock P4I45GV...
The motherboard won't give a response
Jan 20, 2011 | ASUS P4R800-VM Motherboard
How do i replace fan acer 5739g
1.first remove battery and adopter.remove back side covers,wireless lan antenna
2. remove all the screws in bottom side.
3.just above the keboard ,the front panel neds to removed with little preasure from fingers and remove the flat cable jently. remove lcd panel cable,pull out wlan cable in upword direction.
4.un-screw screws over keyboard and lift the keyboard,look at the bottom remove the flat cable(the brown colored lock should be pushed up jently.
5.remove the touch-pad flat cable similarly & remove
any other cables
6.jently pull the top panel towards you with fingers( observr any cables/wires conected to mother board)
7.once front panel is removed remove other cables /wires connected to usb/phone socket/wlan.
8.un-screw the screws with arrow indicater to remove mother board from back panel.
9. remove the screws form heat sink attached fan jently.
replace the fan or heat sink with fan of the same part number.( a.  put few drops of any oil betwen gap pan blade and plastic it might clear dust    b. in case fan is smooth then 5 volts wont be comming from mother board(red wire) then u requir proffesional help ).
10. follow the reverse procedure to assemble the laptop.
*****before you start any work ground ur body start with bare foot as all devices are esd sensitive. try with your own risk iam not responsible for consiquential
damage to device/person .these are just hints to help*****
Mar 11, 2010 | Computers & Internet
Motherboard display problem
Hear some any beeps to your motherboard. If your hear this beeps then motherboard will identify what is the loss connection of trouble of your MOBO.
If you don't then have to remove tor clear the CMOS by removing the Lithium Battery in it.
Sep 29, 2009 | HP (D7580-60003) Motherboard
QDI kudoz 7 mauanl wanted
this time your got have a spammer, i tell you read the USB port at the motherboard then put the wire connection there
Jun 17, 2009 | QDI Group QDI KuDoz 7 Motherboard
Systemax Arrival (036063) PC Desktop Logo
100 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
