Question about Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
I have a Kenmore washer and dryer set HE2 - and would like to leave them in thier current postions. My question is can the doors be swithed to open on the other side?
  • 15,935 Answers
Yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus front load washer: the front rubber gasket is moldy even tho i leave the door open when not used. someone said it is because i have used downey
You can use awsome to spray on let it soa, make sure you get in th cracks ,atfer it soak for awhile use a tooth brooth an brush it. when done with wash open door an d one cup of vinger right in the middle of the tub, that should take of it.
Oct 31, 2011 | Kenmore HE2 Plus Front Load Washer
Who makes Sears washers and dryers? Does Whirlpool make them
The model number on your washer or dryer (located on a nameplate around the door opening) should have a prefix code of "110". This number identifies the manufacturer as Whirlpool. If you need further assistance, please post back and let me know. I hope this helps you.
Oct 13, 2010 | Kenmore HE2 Plus Front Load Washer
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore washer and dryer set HE2 - and would like to leave them in thier current postions. My question is can the doors be swithed to open on the other sid?
You could probably ask any salesman just act like your interested in buying it but you need it to open left handed , they.ll be more than happy to let you know how easy it is to do, or not..good luck,,l think you can do it,
Sep 18, 2009 | Kenmore HE2 Plus Front Load Washer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
We've had our HE 2 plus washer for a couple years, and we have started to smell a slight mildew odor. Is there a trap someplace that needs to be cleaned, or something else I need to be looking for?
You need to use some bleach and clean the washer out. I also wipe the rubber around the door opening and leave the door open airing out the machine. The rubber gasket will grow black mold.
Aug 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
751 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
