Question about Troy Bilt Tb70ss Gas Trimmer
Weedeater starsts and ildes won't run or accelerate
My troybilt weedeater will start and idle with the choke on but when you throttle it up it will die.
  • 1,305 Answers
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
Posted on May 28, 2009
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater starsts and ildes won't run or accerate
It sems to me like your engine chokes itself on a too rich fuel mix, a clogged air filter may cause this condition. Of course there is always the possibility of a needed carburetor adjustment but I would definitely check the air filter first if this machine used to work fine.
May 30, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybilt TB75SS String Trimmer will only run choked to partially choked. I can throttle it and it runs rough but will accelerate with about 1/4 choke. less than that it dies. Not much smoke I expect I...
It sounds like your carburetor needs a good cleaning. You must disassemble the carb., clean all the ports with a small Den Tech Brush, (used for cleaning between teeth). They are very small and perfect for this job. You will also want to clean the small screen in the carb. It may be so clogged that it may need to be replaced. If this is the case, you will need a carb.kit for your Troybilt Trimmer; it comes with small parts and gaskets. (It will come with some gaskets that you will not need.) Replace all old parts with the new ones. This should fix your problem.
May 22, 2009 | Troy -Bilt String Trimmer/Blower...
Will not run on open choke
HI,
I TALKED TO MY SISTER WHICH IS AN INSPECTOR FOR WEEDEATER COMPANY SHE TOLD ME IT HAS CLOGGED FUEL LINE OR THE TANK IS DIRTY. ALSO CHECK THE PRIMER BULB FOR HARDNESS OR CRACKING THIS ALSO CAN ALLOW A LEAN OUT CONDITION YOU ARE EXPERIENCING. EMPTY THE TANK AND WASH IT OUT WITH FRESH GASOLINE. SETTING FOR THE IDLE SCREW IS 1.5 TO 2 TURNS OUT WHEN TURNED OFF AND FULL THROTTLE SETTING IS HOLD THE THROTTLE WIDE OPEN AND TURN THE SCREW IN UNTIL MAXIMUM RPM IS ACHIEVED. HOPE THIS HELPS GOOD LUCK!
Mar 30, 2009 | Garden
My weed eater will start but when I push on throttle it dies
well take the spark plug out take some WD40 and give it a shot inside the unit, remember to keep the unit level when hitting the throttle and allowing it to warm up for a few minutes before use also make sure where your choke lever is. also when starting I start it on the ground like most manuals state and leave it idle on the ground for a minute before picking it up and then when I pick it up I make sure that the gas tank is tilted towards the ground so there is no room for air to get into the filter causing and disturbance while the unit is warming up.
Nov 15, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Troy Bilt Tb70ss Gas Trimmer Logo
2,329 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
