Question about Dell Dimension 1100 PC Desktop
My drive wont read or anything
I put a disk in and nothing happens. It says though under my hardware that the software is missing or corrupted. What do I do to fix this? It is a desktop computer
    New Friend:
  • 37 Answers
Go here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid
Select what operating system you have (xp or vista) then scroll down to where it says "CD/DVD" and choose your specific cd-rom drive model.
Download the firmware and run it. It should function after that.
(Also if you don't know your Cd-Rom drive model, right click on My Computer> Properties> Hardware Tab> Device Manager> Scroll down to DVD/CD-ROM drives and check out the model number.) Hope this helps! :)
Posted on May 28, 2009
I was doing an "update" and when it asked to
Sounds like your update went didn't work right. This could have been caused by a corrupted update file that Vista tried to install or you might have a hardware problem (i.e.bad hard drive). Try running the Dell diagnostics. Do you have any CD's thatcame with your computer? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.
May 15, 2011 | Dell Inspiron 530s Desktop Computer
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Nov 16, 2009 | Toshiba Satellite A135 Notebook
Won't format my CD-RW disks
First try to format manually . 1.) my computer 2.)cd drive right click on it and then format if still nothing happens cd definitely have been corrupted
Feb 10, 2009 | Ahead Software Nero 6.0 (60045) for PC
Dvd rom drive dissapearing!
Hi
had the same problem after a recent windows automatic update, tried everything but sadly had to re-format and start again with system software and sure enough all was well.
DG
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
DVD/CD ROM not working...
delete the upper and lower filter fo cd dvd drive from registry editor
and restart the system
Sep 19, 2008 | Gateway GT5654 Desktop PC
Toshiba Satellite A75-S206 DVD\CD-RW drive problem
Hello GeneMat,
I am Romeet,i will try and help you with this problem.Seems it could be an issue with the Combo DVD Drive's Driver Software or Firmware.
Try This:
From your Desktop:
Right Click " My Computer" Icon and select "Properties"
Go to "Hardware" Tab and select "Device Manager"
Under Device Manager, scroll down to the "DVD/CDROM Drives" menu and click on the plus ( + ) Sign next to it
Right Click the Drive name eg " Toshiba DVD-R TSST 2313" and select " Uninstall" Click yes to any prompts and restart your Laptop.
After rebooting, Windows XP should pick up the drivers again, so wait a while for it to complete and until it notifies you that " Windows successfully completed installing your new hardware" or something to that effect and then try using the software cds again
Best of luck!
Regds
Romeet
Dec 01, 2007 | Toshiba Satellite A75-S206 Notebook
External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Oct 06, 2007 | Western Digital My Book Essential Edition...
Dell Dimension 1100 PC Desktop Logo
82 people viewed this question
Alun Cox
