Question about Samsung DynaFlat TX-P3076WH 30" TV
Searching for signal, component connection
Lately, when I watch TV for about ten minutes the TV starts to search for signal.  After a few minutes the signal comes back and there is no problem for the rest of the day.  At first I thought it was a problem with the cable box, but my DVD is also connected via component cable and the next time it happened I tried to play a DVD.  When I switched from cable to DVD connection, it would still search for a signal.  The set is about 2 years old
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • the problem is in the system control section of your tv
  • it might be due to loose connection in that section
  • some components must have failed.
  • loose contact in any pin of system control ic.
  • good luck.
Posted on Oct 22, 2007
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
What is wrong with my Samsung HLS42WX/XAA everytime I turn it on after ten minutes the volume start making a loud crackling sound then there is no volume sound at all. What do I need to do to get this
It clearly may be a sound problem in the set but a few things you might check, First of course is do you have this issue on all inputs including the rear ones, does a DVD player connected to a rear input do this or not?
If you have a box connected to this set unplug both the box and set from power for a while, cannot hurt but may help.
If using a box and set does not do this with a DVD it may be possible to get around the problem.
A box or even the tuner in the set may be the cause==your tuner not only processes regular signal but also develops the sound signal, it may be bad.
Dec 23, 2012 | Televison & Video
2008 Toshiba 46XF550u flat screen TV.
tried to check first loose connection connector or cold soldered component parts like ic in the X board, which send signal at the screen panel display.if ok, look for the t-con board re seat the lvds cable connector.then if can not get with re seating the t-con board must have bad component parts.
Sep 07, 2012 | Toshiba 46XF550U 46 LCD 1080P Refurbished...
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
Power/Connection Problem
May be the power supply.
Might be worth replacing or bringing it to a repair shop for them to diagnose, most diagnose for free.
Mar 25, 2010 | Sony PlayStation 2 (PS2) Console
Loses source signal to the PC after heating up.
I would first make sure the cable is not having an problems. But when I worked at a repair shop the main board was always the problem when giving these symptoms.
Nov 13, 2009 | ASK Proxima M1 Multimedia Projector
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
My phone froze up while in a no service area and is still searching for a signal
Did you try turning it off and back on? Try removing the battery and keeping it out for at least ten minutes, then putting it back in before you start it up again.
Jun 05, 2009 | LG RUMOR Cellular Phone
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Samsung DynaFlat TX-P3076WH 30" TV Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
