Question about Maytag Neptune FAV6800AW Top Load Washer
Softner cup is not draining completely on Maytag Neptune TL
I think there might be build-up. Is there a way to 'flush out' this drain?
Thanks,
Dot
  • 335 Answers
Dot,
If your machine is a FAV6800AW/FAV9800AW See if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove some gunk. If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue. Rich
Posted on May 28, 2009
I have a Maytag Neptune TL Washer that won't drain. I think the drain pump is clogged. How do I remove/disassemble the cabinet so I can get to the drain pump?
See this link for the Service Manual and a pic of Drain Pump/Drain Line on the right side of the machine. leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you
You can place the machine in Service Mode once you have the Service Manual and turn on the drain pump thru console commands.
As I mention in the other post here on FIXYA you can only access the drain pump with the front cover removed.
If you place the machine in a Spin Only cycle will it complete the cycle?
If you can give a bit more detail on your troubleshooting maybe I can help.
Sep 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softner won't drain
If it is a top loader:
PULL of the fabric softener cup straight up
Rinse out thoroughly
Clean out the holes in the side of the agitator
Nov 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Not draining completely
Clutch Fix
Hello surfsmitty68 ,
A couple of questions;
Is the machine failing to spin with error codes such as dc or UC? If not are there any error codes to the LED console display on spin cycle failure? If there is a blockage in the drain pump/drain line you would fail with a ND error code.
Do you want to DIY the repair once we get going or do you want to call in a repair service? See this post Clutch Fix to see what is involved to re-lube/replace the clutch in the FAV6800AW or FAV9800AW TL. If you or someone has basic mech. skill sets you can do this it’s just a tight work area. But let’s get some feedback from you before we commit to a clutch issue.
Here are some handy links; The Service Manual for reference. Sears Parts Direct for reference.
Post back if you have questions or concerns I’m a owner like you. Let me know what I can do to help…. Rich… aka dh1200s.
Nov 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL fabric softener cup seems to be clogged, what do I do?
If your machine is a FAV6800AW/FAV9800AW see if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove gunk build up.
The Service Manual for reference use and care guide has some info
Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Jan 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Sep 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
468 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
