Wiring separated from 9 pin female Rs-232c serial adapter
Our multi media projector b/c disconnected from the ceiling mount and the wiring separated from the 9 pin serial adapter leaving the adapter attached to the projector and the wiring exposed. My question? How would I rewire the 9 pin serial adapter without replacing the entire cable? Please help. Thank you, Terry tdbvvrc@yahoo.com
  • 77 Answers
Strip off an inch on both ends of the wiring you are trying to connect. Connect each wire with the same color. Example if the 9 pin side wire is yellow/blue then the other end needing to be connected will need to be yellow/blue. Twist them together and use a terminal splicer to fastened and protect them from touching each other. Do this until all wires are spliced together color for color.
Posted on May 29, 2009
Were can i buy 9 pin cab;e
Shop for 9 pin cable on Google
9 pin serial cable ' Staples®
www.staples.com/theme_9-pin-serial-cable
Staples Inc.Items 1 - 18 of 8325 - 9 pin serial cable (8325 items found) .... Professional Cable (9); Voxx (9) ..... QVS 4.5' USB/DB9 Male to Female Serial Adapter Cable, Black.
Sep 25, 2015 | Video Cameras
I have to reinstall Zebra LP2824 to a new computer windows 7. I do not know what port to use to install it?
I believe this printer only has a serial (RS-232C) port. You may have to install an adapter card. Before you do that make sure a Windows 7 printer driver is available for that printer.
Jul 20, 2011 | Office Equipment & Supplies
Hi! What cable/adapter should I buy so I can use foot pedal in my laptop using USB? Foot pedal is 9-pin, used for transcription. Thank you.
The following link should meet the requirements assuming your existing cable is defective.
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10311&cs_id=1031104&p_id=2276&seq=1&format=2
Feb 28, 2011 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Wanting to mount this projector from ceiling. How and what bracket should i use.
get the epson parts
ceiling mount ELPMB35
ceiling mount adapter ELPMBAPS
Feb 22, 2011 | Epson PowerLite 50c Multimedia Projector
I need sabrent usb to serial converter drivers.The disk I received with my parches does not load!?
Try searching the following page
http://www.sabrent.com/#itemName=&itemID=0&section=Drivers
Feb 20, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Driver needed
I found my disc. Problem solved. Thanks for follow-up.
Jan 11, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
