Question about Carrier 38CKC036 Air Conditioner
Carrier Infinity from 1994 does not start
It has a little blower that starts but no flame.
  • 1,420 Answers
The Carrier Infinity has a control board that will flash out a pattern giving you a hint of what could be wrong. To find it, remove the cover off of the furnace and you will see a small round clear window. Look and count the blinks. Then compare that number to the diagnostic chart found on the back of the furnace access cover.
Let us know what the pattern is and we can help you more.
Posted on Oct 22, 2007
  • Chandler Ede
    Chandler Ede Oct 23, 2007
    The diagnostic codes are found by counting the number of blinks of the amber light viewed through the little clear viewing port located on the bottom section of the furnace after the main access panel has been removed. The light will either flash slowly but constantly, flash rapidly and constantly or blink once or twice followed by a pause then again for a number of times than another pause. These last blinks are Status Codes and will be required to diagnose your furnace. For example, the light blinks twice than a pause then 5 more times. this is a Status Code of 25.
    If you can get this plus the model number of the furnace, which is located on, the left side of the furnace inside the cabinet after the main access door has been removed. It may be something like 58MVB060-F-1-20 or like that. We will be able to give you more direction.
Carrier troubleshooting furnace
If the thermostat isn't selected for "FAN" then the relay is stuck. In heat mode the thermostat opens the gas valve and starts the igniter and the induction motor. If the induction fan isn't running, the flame will stop.
Jan 28, 2014 | Office Equipment & Supplies
I have a carrier furnace and the led light is blinking 3 short then three long what is the code
code 33 LIMIT OR FLAME ROLL-OUT SWITCH IS OPEN - If open longer than three
minutes, code changes to #13. Flame roll-out switch requires manual reset.
Check for: - Dirty filter or restricted duct system. - Loose blower wheel.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch or fuse link open).
- Open Flame Roll-out switch, or fuse link. Manual reset or replace.
Apr 19, 2011 | Carrier 38BRC036 Air Conditioner
My heater flame ignites but when blower starts the flame shuts off does any one know whats the problem
Sounds like a bad heat exchanger. The flame could be coming out, and throwing the Flame roll out limit switch. Could just be limit switches.
Dec 20, 2010 | Carrier 38CKC036 Air Conditioner
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
Feb 13, 2010 | Heating & Cooling
Flames will not start even though igniter glows
i am not very familiar with this particular model but something must tell the gas valve to open.there must be a thermocouple or optical scanner that creates a signal to open the gas valve. if there is a signal to the gas valve then the gaas valve will need to be replaced
Oct 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace sometimes will not stay lit
Check the heat exchanger for a crack or hole. The room air blower is blowing back into the heat exchanger extinguishing the flame. Have it checked out today. Did you get it checked yet? Now. Have I stressed to you to get it checked out yet or have you been overcome by Carbon Monoxide yet?
Dec 10, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier model 58sxa080-gg series 100
the flame detector rod is dirty? try cleaning with sand paper and scraping also. there should be a small amp. reading threw wire coming from flame detector rod. in milli amp range. increases when running. some times i use a jumper to hold gas valve on once started to allow time to test amps.
Feb 19, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC036 Air Conditioner Logo
242 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
