Question about LG KU990 Viewty
Video call doesn't work
I dial the number, press the appropriate button and it says video call servce unavailable what can I do to change this?
  • 19 Answers
For video call to work, you have to be in a 3G covered area. This means that the icon over your signal level bar must be full and have 3G written in it. It wont work if it is running on a low 3G band (the signal bars must be full) a GSM band (a G logo above the bars) or HSDPA band ( a H logo above the bars).
I don't know why even though HSDPA is faster than 3G but the viewty will only allow video call to take place when 3G is available.
I've heard it can also be dependant on your service provider, as PAYG sim cards sometimes wont allow video calls.
Posted on May 29, 2009
Have bought a Technika DAB 109 CRF radio and no instructions. 1. how do I tune it and SAVE to presets 2. How do I set the alarm? Thank you
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Feb 20, 2011 | Audio Players & Recorders
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
We have comdial impact 8324 phones here. One of our employees no longer has a DSS button that transfers calls directly to someone's voicemail. How can we program that back in?
Try this:
Storing a DSS Number -
Only one DSS number may be stored at each programmable button location but you may store a feature code or autodial number on the second level for a button location that already has the DSS programmed.
To Store an Intercom Extension Number as a DSS Number :
  1. Press optionS
  2. Press NEXT four times
  3. Press DSS
  4. Press the programmable button
  5. Dial the extension number
  6. Repeat as many times as desired
  7. Press SPEAKER to end.
NOTE: Do not program interactive buttons. If this occurs, you can retrieve functions by pressing INTERCOM "**1" , the interactive button and dial 91, 92 or 93 (from left to right). Attempting to program these buttons can cause features to be unavailable.
You can get more information from:
http://www.mainresource.com/PhoneTipsComdial.html#programming
Nov 04, 2009 | Computers & Internet
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Video capturing size question
You have two choices for Video size when creating MPEG4's. 320 x 240 or 160 x 120. Use the following instructions to change the size. Digital Still Camera Mode 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to CAMERA mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY. 5. Press the ENTER button to enter the submenu. 6. Turn the MENU DIAL to highlight MPEG4 SIZE. 7. Press the ENTER button. The MPEG4 SIZE toggles between 320 x 240 / 160 x 120 with each push. 8. Press Menu to Save and Exit.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Noise during video recording
Turn off Continuous AF (auto focus) to prevent recording camera noise during video capture. When you turn off Continuous AF, you may notice a narrower area of focus or depth of field, especially if you zoomed to a telephoto position before recording. Turn the Mode dial to Video, then press the Menu button. Highlight the Continuous AF menu, then press the OK button. Highlight Off, then press the OK button. (On is the default.) Press the Menu button to turn off the menu screen. This setting remains until you change it, change the Mode dial, or turn off the camera.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
LG KU990 Viewty Logo
222 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
