Question about Panasonic KX-TGA650B (037988474806) Cordless Expansion Handset
WILL NOT OPERATE BEYOND FIVE FEET OF BASE STATION
KX-TGA650B HANDSET OPERATES ONLY WITHIN 5 FEET OF BASE STATION. HOW TO EXTEND RANGE TO NORMAL? IS ANTENNA BAD? hOW TO CHECK ANTENNA?
  • 94 Answers
If there's no low Battery indication, it'a the antenna. It should unscrew and you can install another one the same way.
Posted on May 29, 2009
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Feb 15, 2012 | Panasonic KX-TGA650B 5.8GHz 2 Line...
KX-TGA650B manual
Here is a direct link to the User's Manual for your phone:
http://www.barclayent.com/manuals/Panasonic%20KX-TGA650B.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Oct 01, 2011 | Panasonic KX-TGA650B (037988474806)...
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TGA650B (037988474806) Cordless Expansion Handset Logo
160 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
