SOURCE: Hi my 2004 suzuki forenza is only blowing out cold
Only solution for this givin the circumstances, is that when he did reconnect the dash, he didn't reconnect the plastic tubing that's connected to the vents. Have you checked the radiator fluid or do you smell radiator fluid. Because also, sometime times the heater core is located under the dash against the firewall and he could have punctured it or disconnected that too. As for the radio, its very possible he didn't connect it right. He didn't have to take the dash off either to replace the radio. it should slide out of the dash pretty easy and they make an adaptor for the wiring harness.
