Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
I recently bought IDJ2, i keep hearing static from my speakers when i plug it in. I have to set the volume on the mixer at a quarter in just so i don't hear the white noice; but the music sounds extremely low. However when i plug a dif mixer with the same RCA Connectors - works just fine. Pointing out, i can't raise the volume on the IDJ2 mixer because i get static at over a quarter turn of the master volume. thanks for the help.
    Problem Solver:
  • 6 Answers
I hav the idj2 and i was expericing the same problems, i am a dj sponsored by numark and they said it's just a little dusty. got to walmart, or your local pc store and pick up an air duster can.unscrew screws located on the bottom of the unit and make shure not to disconnect any wires, then jus blow out all the dust in the inside of the unit, but make shure the air duster dosen't drip on any of the electrical system, make shure you get the usb ports and the ipod dock to then put it back toghter and it should work fine, a temporarry soution i found before i found that is when the static is on turn it of unplugg it and shake it upside down that also helps for the time
Posted on Jun 22, 2009
With the Mackie PPM608 Mixer, our passive speakers aren't working. We use CVi-252s, but I'm sure it's an issue with the mixer rather than the speakers.
Get a plug cable and work the plug in and out of all INSERT or BYPASS jacks. These get rusty and interrupt signals.
If that is a no, open up and check power supply voltages and all cable connectors, might have been vibration and something got loose...
PEACE---
Jan 31, 2016 | Mackie PPM608 Professional Powered Mixer
Headphone distortion and a hum sound feedback issue when using external speakers
Sometimes empty/unplugged channels introduce noise to the amplifier. You can always try to connect all of the input channels to some external mobile phone/mp3 player, etc. and then set these equipments to the minimum possible volume (mute if possible). This should remove the "atmospheric" audio noise.
Dec 27, 2013 | Hercules DJ Console RMX
Cant get speaker to work hear only static
First try to attach the speaker to another device, DV Player, Amp, Audio Receiver, etc. See if the set works on any other device and if they do; the problem is with the computer sound in or software that allows the speakers to generate sound-out. Check also that you have the computer set to play sound! Look at the speaker symbol at the lower right of the screen and it should indicate it is active. Right click and it should tell you if it 100%. Open the Volume Mixer and see if your speakers are recognized and set the Volume. Always make certain the speakers are attached to the proper GREEN in port on the sound section on the back-side of the computer. If you have more than one colored plugs, be certain to insert according to the color.
Dec 19, 2013 | Audio Players & Recorders
Can you help me to reinstall my computer with no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 09, 2012 | Gateway Computers & Internet
I just bought the Idj2, How do you get the ipod
slot it in the top and it will load to the display
Jan 22, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
I get no sound from my speakers
If you are saying that you are connecting the idj2 directly to the speakers... Yes, You need a amplifier. Most DJ mixers only "pre-amplify" the sound signal (like the idj2 does), but there isn't enough power to drive a set of speakers.
The path goes like this...
idj2 or cd players&mixer===>Amplifier===>Speakers===>Party
Aug 15, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have static in my microphone on my idj2
My idj2 gets the same problem after 3 hours. For two hours it sounds good, I am using a shure sm58 radio mic. The only way i can get rid of the static sound is re booting the system then its ok.
Mar 05, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
420 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
