Water leaking from ice maker
SOURCE: Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
SOURCE: leaking pure source 2 ice and water filter
Hi-
Three things
Hope this help
Open valve completely.
Supply valve must have a 1/4" opening for
water to fully supply ice maker. Many self-piercing valves do not have
this big of an opening. Replace water supply valve with one that has a
1/4" opening.
If equipped with a water filter, replace filter canister or cartridge.
Thanks for using Fixya!
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
