Crackling the right speaker channel crackles very loud. this happens even without any input and with the volume muted
  • Audio Player... Master
  • 5,190 Answers
Possibly bad news I am sad to say. You might have lost the transistor in the right channel output Or if it is an IC that. The things on the heat-sink! However you might be lucky and it might be just either a bias resistor or a ceramic capacitor. The small components are cheap the bigger ones tend not to be. Resistors often look burnt, but apart from that is a case of replace and see.
Posted on May 31, 2009
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
Hi...I have an old Sanyo DC6100K 4 Channel Stereo System (circa 1970's). Still works OK except the right rear speaker outlet has developed a loud crackling. Changing speakers does not help. The crackle...
To the original poster I just inherited one of these machines. Afraid I cant be of much help with the speaker issue but mine was missing its turntable belt. Any chance you know of measurements or model or somewhere I could order a new one? Same question for the stylus?
Jul 31, 2013 | Audio Players & Recorders
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Car speakers crackle even with thw volume all the
turn the bass all the way down if it still does it your speakers are bad or the deck needs replaced but its more than likley the speakers
Aug 10, 2009 | Car Audio & Video
NAD 3020a crackle in right channel regardless of volume.
more than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
Jul 26, 2009 | Audio Players & Recorders
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
114 people viewed this question
 Grubhead
Grubhead
