Question about Comfort-Aire HMC24AD-1 Air Conditioner
Energy Knight AC Blowing Fuses
I have an Energy Knight HMC24AD mini split unit. The past few years it would blow the 250V 3.15A slow blow fuse that is in the exchanger outside. I could change the fuse and have no further problems for the rest of the season. Well now as soon as I turn on the breaker it literally blows the fuse (into pieces!). I've done some reading and most talk about the contactor but this unit doesn't seem to have your standard contactor or at least it doesn't appear like others I've seen. I can not find any info on these units so any advice or suggestions would be greatly appreciated. Thanks in advance!
  • 1 more comment
  • michael_eide May 28, 2009
    I believe you're correct on how the system is controlled with the relay, rectifier bridge, etc..after taking another look. I figured it was a short also and looked for obvious signs such as rodents, bugs, anything. There is obvious signs that mice have been visiting the system outside for its insulation and we also have a number of chinese bettles but I found nothing. Anyways, I really do not know where to begin to look for a short in the circuit. There a lot of circuit boards and not really a lot of wiring. I'll actually try taking a picture and see if I can't attach it. I really appreciate the fast response and great information. Please keep it coming!
  • fougzki May 11, 2010
    Ok I am speaking in general repair.You can begin looking, start after the fuse.It should be AC source-fuse-relay switching contact- and commonly the 3.15A fuse is connected in fan. If the fuse is within outside exchanger most probably it is connected to the fan of the exchanger. Do you happen to see the exchanger fan run? If not then it is a strong probability. Since it is visited by a mice check also it wirings, could be an open in the insulation and touching each other or the chassis. Don't forget also to check the terminal block(if ever it have) could be corrossion and help in making chassis ground or terminal bridging. And also does the fan have a capacitor? check it also if defective. Dry up capacitor act as a shorting wire if defective. And for the last is the fan itself(stuck, dirty, burned).
    Hope I give you some informational data.
    Goodluck and regards.
    You have a short circuit in the system. Is this is on a control module? Could be this unit is controlled by an electronic controller using a relay together with a bridge diode, filter capacitor and a control IC. That is why you are not seeing any contactor.
    And commonly since it is aircon insect, house lizard, and dirt can do short circuit in the system.
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
Posted on Jul 12, 2010
Blowing a fuse up turning the selector on position.
I'm guessing this is a large Pro Espresso machine. 250V/15A is a bit low as they usually range in 25A which should be on a 250V/30A line. Not your normal home outlet unless your using a washer/dryer outlet. You need an electrician to check if this much power is available on your premises. Check the nameplate rating on the machine to confirm this. If everything checks out and your still blowing fuses then the heating element needs checking. Blown (cracked) elements will short out in a tank of water causing over boiling and high steam pressure. Serviceman should check this as there are dangerous voltages present. Aloha! ukeboy57
Sep 16, 2017 | Miele CVA610
My ac is not blowing cold air?
There can be multiple reasons for this. Is the outside condensing unit running? and this is assuming that the wall hung AHU is blowing? Also is there any tripped breakers/ burnt fuses, etc.? With a few more variables answered we may be able to come up with the solution to your problem.
Sep 23, 2011 | LG LS-L1210CL Mini Split Air Conditioner
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for...
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
Oct 07, 2017 | Audio Players & Recorders
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
What amp is the power fuse for the tv listed below?
Fuse rating would be 3,15A 250V for this tv.
Hope this info will help you.
Thanks.
Nov 10, 2010 | Astar LTV-2701 27 in. HD-Ready LCD...
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Comfort-Aire HMC24AD-1 Air Conditioner Logo
1,525 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
