Question about IBM Computers & Internet
Need manual for l-nc51m motherboard
I need a manual for this motherboard. It has a Lenovo CPU. fan the procesor broken, proccesor ok, no volt in pin the socket fan,driver transistor ok; my computer is lenovo thinkcenter motherboard l-nc51m. Thanks Hideky
    President:
  • 623 Answers
You did not mention which ThinkCentre model you are using, but I know that the Lenovo 3000 J115 is using this motherboard. Look at the hardware manual from Lenovo (link) and see if that is what you are looking for.
You can also try to locate it yourself (link)
If this is not the right one for you, just come back here and leave a comment with more details about your computer - I'm happy to help.
Posted on May 28, 2009
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
I need the manual that shows the Lenovo L-NC51M MoBo and describes it in detail.
http://www.user-guides.co.uk/download/lenovo/lenovol/lenovo-l-nc51m-pinbelegung.html
Sincerely
Aleksandar Adzic
Apr 18, 2010 | Computers & Internet
HP Desktop 792n Intell 4 CPU fan won't come on. Overheats, shuts down. Fan checks out OK. Replacement fan won't turn on either. All works fine with external house fan blowing on CPU
Check the pins on the motherboard where you connect the CPU fan. Could be just a broken solder joint. You can connect the CPU fan to another connector for an alternate fan as a temp fix, especially if you are not adept at soldering.
Lenovo J115 with new Gigabye motherboard - case fan set up
Lenovo's web-site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
should have the information.
What connectors are leading from the front-panel?
One "clump" of wires and one connector, or several separate connectors?
May 27, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
Unable to upgrade my processor coz no motherboard specs.
You cannot replace AMD processors with Intel processors. because their pin packing and pin count and interface to the motherboard is different. you can upgrade to same AMD company.
and you can find your motherboards as well as computer specifications in here
http://www.associatedcontent.com/article/342263/lenovo_3000_j115_desktop_review.html?cat=15
Apr 20, 2009 | Computers & Internet
My computer isnt turning on
Make sure the BIOS settings are correct for the microproc and also make sure the motherboard supports a dual core processor.
Apr 07, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Ga-7N400E powerup problem
VRM Circuit problem found there
disconnect only core voltage connetor and power on motherboard
if motherboard on so confirm that your vrm circuit is sort
replace vrm circuit mosfet
Feb 23, 2008 | Gigabyte GA-7N400E-L Motherboard
Upgrade my computer procesor
Socket type: mPGA478 (P4).
P4 – 1.4-3.4 GHz
P4 EE 3.2-3.4 GHz
MOTHERBOARD MANUAL: http://www.elhvb.com/mboards/OEM/HP/manual/danube_manual.pdf
It shows you how to take off and put in the CPU.
This is a guide on how to install the CPU/with FAN.
http://www.pctechguide.com/tutorials/Pentium4_CPU.htm
Nov 11, 2007 | ASUS P4B266 Motherboard
Can I use Athlon X2 procesor with this mother board?
It takes Socket-939 processors (AMD Athlon 64/Athlon 64 FX [K8]).
X2 processor used Socket-AM2
Nov 11, 2007 | PC Chips A21G Motherboard
Computers & Internet Logo
5,174 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
