Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
Incoming faxes jam system
Win fax 10.03 Sometimes the program works fine. Other times, when it idicates a fax is coming in, the program stalls (fax essentially fails), and I cant cancel the incoming fax. I have to reboot my CPU in order to clear it. This happens at least once a day and it is not the same fax number crashing my system. Any ideas?
  • 143 Answers
This can be any number of problems, like corrupt logs, too many entries in your default log structure, or simply a bad modem setup. You can check this link regarding rebuilding your logs:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=Help;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Posted on May 29, 2009
Car will turn over or start
Hi Kay, I'm glad to help! Kay, if you turn the key on and nothing happens at all. In other words: You do not here the engine turning over and sometimes the dash lights and guages do not work. Here's your most likely problem. Your vehicle has what they call a WIN Module which is the same thing as an old style Ignition Switch. When the WIN goes bad it's shuts everything down and nothing happens when you turn the ket to the start position. This WIN will need to be replace at the dealership because they will need to program the WIN and then program the KEYs to the new WIN. NOTE: DO NOT be alarmed if the tell you that you need new keys because they want program to the new WIN, sometimes this happens in fact so often that the manufacture started sending NEW KEYS with the WIN, But, only on some year models. Hope this helps and have an awesome day Kay.
Apr 07, 2014 | 2006 Dodge Stratus
I have a brother intellifax4100e and when ever i touch a button to send a fax dialing from the keys or using a programmed key - the machine beeps three times. I cannot send any faxes and i have tried...
When you get a treble beep it can be an idication that there is a key stuck down. Check every button to make sure it clicks ok. i bet you have one stuck.
Aug 18, 2011 | Office Equipment & Supplies
Hi sir im jeff and my question is that i cant scan my computer windows 7 prof using windows live essentials.
Hello
I am also using win 7 home premium.With microsoft security essentials.
There could be a few reasons why its not working for you.
1 If you have another anti virus program it must be completely un installed.
2 You downloaded win 7 32 bit, and not win 7 64 bit version.
3 Download corrupt.un install essentials and re download and install.
Hope this helps.
Thank for using Fix ya
Feb 06, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Download Microsoft Essentials and removed several times. It appears in the taskbar but when the computer is turned off and then on again, it has disappeared from the desktop. It states that it is already...
If you can not uninstall Microsoft Security Essentials normally, press "Win+R" then type regedit and press enter, find the key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft Security Essentials and delete it. Then re-install the program and uninstall it and you'll remove Microsoft Security Essentials from your computer completely by this way.
Aug 02, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Engine failure
Sounds like the crankshaft sensor may be failing. Take your vehicle to autozone and have the computer scanned for the error code or issue. They will do it for free!! Post the code if needed. Crank positioner sensor failure symtoms: Hard/long starts (hot or cold), misfire, random stalls, poor performance, service soon idicator lit. Hopefully this helpd!!
Mar 31, 2010 | 1999 Oldsmobile Intrigue
Format Problem???
hello!
Try running it on win XP ,you have to install win XP on your pc or any other program to access the harddisk .
good luck
Oct 06, 2009 | Western Digital My Book Essential Edition...
AC blower won't come on
The problem is most likely the AC compressor clutch connector. It is a one pin connector. Located under the hood, near the clutch of the AC compressor. Clean this connector, make sure there is a good connection. I had the same problem and had to fix it myself. Works fine ever since.
Aug 11, 2009 | 2004 Kia Sorento
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
656 people viewed this question
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
