Question about Praktica Luxmedia 5203 Digital Camera
When powered on, lens system makes noise, doesn't move
Rich R6. When I turn the power on, the lense make a mechanical noise (3 times) and does not extend or even open the lens cover. I can repeat this over and over, and nothing happens. Is there an easy fix? I'm thinking about selling on ebay as a broken camera, as the CRIS repair estimate is $160! Hi, I have a similar problem with my DCZ5.8. It was dropped whilst the lense was out, and now its jammed and crooked. When i turn the camera on, it makes the 3 mechanical noises and does not do anything else. I hope there is a way of fixing this as the camera isn't actually mine.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
As an experienced eBay seller, I have sold many broken items over the past ten years. They sell well and it's truly better than having them just sit there and taunt you. If the owner doesn't mind, listing it on eBay to recoup some of the money is not a bad idea. Write up an honest listing describing the camera's problems and history and take just one or two good photos to post with your description. It's what make eBay fun for both seller and buyer -- GREAT DEALS!
You've got a great start to your description already written. "Rich R6. When I turn the power on, the lense make a mechanical noise (3 times) and does not extend or even open the lens cover. I can repeat this over and over, and nothing happens. The CRIS repair estimate is $160."
EBAY HINT: List on a seven day auction ending on a Monday night in the beginning of a month for maximum price.
-CBR2009
Posted on Jul 11, 2009
Shutter is not opening in PL-90
A stuck automatic lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it:
METHOD 1:
Point the camera straight down into a vacuum hose (while the vacuum is on) and tap it around the insides. This will help to **** the dirt out instead of pushing it in further like compressed air might do.Also turn the camera on and off constantly while doing this.
METHOD 2:
1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible.
2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degrees to clear out any debris that may be in there.
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work then it may be necessary to open the lens barrel to access the lens cover mechanism.The lens cover mechanism is usually accessible for many cameras without needing to open up the camera case.
May 31, 2011 | Samsung PL90 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Lens cover won't close and there is internal dust
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
Apr 16, 2009 | Canon PowerShot A560 Digital Camera
My panasonic DMC-TZ15 is stuck on open and the camera will not turn on or off.
Try a new set of batteries for your camera and try to switch it on.
If that doesn't help then try these,
A stuck automatic lens cover may be your problem, but it is normally easy to fix.
Try these:
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off.But this step may not be a option since your camera is in a dead state.
Repeat the above steps several times. If repeated tries don't work (keeping in mind that it usually does),
But if you still got the warranty , you better leave this repair work to the panasonic service center.
Refer to this site for support.
www2.panasonic.com/consumer-electronics/support/Supplies-Accessories/Cameras-Camcorders/Digital-Camera-Accessories.75681
This is just initial help, tell me how things turned up, so that i can follow you up,
Waiting for your comments.
Hope my info helps you,
Thanx for using fixya,
Sep 30, 2008 | Panasonic Cameras
A730 Lense extended
yeah I got screwed buying a samsung camera too.
Samsung screwed me out of a rebate on a computer monitor before too.
I will never buy another samsung product!!!!
May 26, 2008 | Samsung Digimax S730 Digital Camera
Lense will not close properly
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Praktica Luxmedia 5203 Digital Camera Logo
94 people viewed this question
Top Praktica Cameras Experts
Jose Ma DM.
Jose Ma DM.
Are you a Praktica Camera Expert? Answer questions, earn points and help others
