Question about Sanyo SR-3660S Compact Refrigerator
Defrosting Accident = hole
Accidentally popped hole in freezer thingy. Can it be fixed? Or is there a replacement part I can purchase?
    Director Badge:
    Uploaded 100 video answers.
  • Sanyo Master
  • 489 Answers
Check how to replace evaporator in my video. Hope That helps
Posted on Dec 13, 2015
  • Sanyo Master
  • 43,501 Answers
Depending on where the leak is it is totally fixable, or you can also replace the part...
Also check out this tip though...
Adding Freon to an air conditioner or refrigeration system takes very specialized equipment and years of experience...it would be impossible and irresponsible of me to try to tell you how to do it through a computer.
Let me explain this further….
In small refrigeration systems such as you have in a refrigerator or a beveage cooler, the amount of freon in the system can often be measured in ounces of weight. Many times, just a few ounces. To get these charged correctly takes tons of experience and very finely tuned equipment. Just removing the hoses can release enough freon to make the difference between the system working or not working. Very sensitive scales are needed to weigh in the freon. To make sure the correct amount of freon is in the system the system must be evacuated to a complete vacum before chargeing. This takes a special vacum pump to do this.
To add to this, most small systems are factory charged and sealed. They do not have access ports built into the system. To do anything to these system an access port must be correctly placed in the system for proper evacuation and charging. Then also add the the equation the fact that if you need to add freon to your system, where did the exsisting freon go? Finding and fixing very small leaks also takes sophisticated detection equipment.
The next problem is the many different types of freon that are used today. Some equipment has the type used, very clearly marked, but many do not. Only knowledge and experience can tell what type freon is in the system, and then it can be very difficult sometimes.
Air conditioning systems can be a bit more forgiving, but are getting more and more difficult to analyze and figure out exactly what is going on. The many types of refrigerant and variable speed compressors are making troubleshooting very difficult. Add temperature sensors and variable speed condenser fan motors into the mix and it becomes a nightmare.
Heat Pumps are very sensitive to either under or over charging. The only correct way to charge a heat pump is to evacuate the system and weigh in the correct charge.
Leaks in heat pump or air conditioners are often very difficult to find, also. But finding a leak and fixing to correctly is the only way to achieve a successful repair of an air conditioning or heat pump unit.
So hopefully now you can see that refrigeration, air conditioning, and heat pump system charging is not something that can easily be done without the proper training and equipment.
Oh, and did I also mention that it is illegal to handle and repair any type of system the contains any type of refrigerant with out a refrigerant handling certification in the United States? Yes, and the although rarely anyone has been charged, it still is the law.
Please call for a certified repair technician to repair any refrigeration system and do not try to do it yourself.
Posted on Aug 19, 2010
Accidentally broke a cooling coil in refridgerator, stove, sink combo unit, now it doesnt seam to work?
Sorry but get ready to buy a new unit . none that have had ICE picks rammed thru them have been fixable we use a hair dryer on ours .
Sep 05, 2015 | Refrigerators
Fan in freezer has stopped working,have defrosted and fridge seems to be cooler.
Simply defrosting the freezer might solve your problem. Sometimes ice can form on the fan or fan motor, and of course, prevents the fan from turning.
If there is ice here, your refrigerator isn't defrosting properly. This sounds like a defrost problem that may need a part replaced. Check out this site for details and photos. Refrigerator Defrost Parts
May 07, 2014 | Refrigerators
Water buildup inside refrigerator. Source back or fridge from freezer section. It appears it is defrosting all the time.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 25, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My GE refrigerator, freezer is a side by side, model # TFH30PR - 1994 purchase. Sudenly I am getting ice build up on the freezer floor. My research suggests a plugged drain hole - but I cannot find the...
Remove the food from the freezer from the icemaker down . Remove the 6 (?) screws holding the rear panel on . At the bottom below the coils , there is a drain hole . Start from the center below the coils , defrosting with a hair dryer . Eventually you'll see the hole . keep defrosting the hole until excess water starts going down the hole or if you think the hole is clear , use a small hose inserted into the hole and blow thru to remove any built up food debris in drain . After clear , reinstall the panel and frozen food .
Aug 09, 2009 | Refrigerators
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Accidental defrost
I did the same thing. I know it's a little late now but for anyone that does this again here's what to do. There's a thermostat in your actual freezer you might not be able to see it, because it might be covered in ice. It looks like a tiny tube, To stop the defrosting all you have to do is warm up the thermostat either pressing a hot towel agaisnt it or meltling the ice with a dryer (but be careful)! After a minute or so the red button should pop out again and the refrigerator will start humming again. Unplugging the refrigerator will not reset anything and don't try to pop the red button out of your own!
Feb 27, 2009 | Danby Compact Refrigerator DCR-101W
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Sanyo SR-3660S Compact Refrigerator Logo
278 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
